89-91 civic hatchback starting problems
Old 02-13-2012, 02:28 PM
97ser's Avatar
Default 89-91 civic hatchback starting problems
look i know this can be found but I have googled everything i could think of and nothing is coming up. Anyway, I am tryin to but a friends civic hatchback original carburated motor. I looked at the ecu codes on the car and all it does is blink once wait a second or two blink again.........over and over. The car just starts runs for a second then shuts off, but if you give it gas it struggles but runs. anyhelp?? thanks
Old 02-13-2012, 02:51 PM
KINGVEM^^ED6's Avatar
Default Re: 89-91 civic hatchback starting problems
Vacume lines?
Old 02-13-2012, 03:11 PM
crvtectim's Avatar
Bad ignition switch?
Old 02-13-2012, 03:28 PM
90_EX_Civic's Avatar
do you have pics of the engine? and you say it's carb??? you sure it's a 88-91?
Old 02-13-2012, 03:35 PM
HondaMotive's Avatar
Are you sure this is carb or is it single injector that looks like a carb?
Old 02-14-2012, 03:17 PM
97ser's Avatar
dude honestly i have no idea im going to buy the car for 500 if its something i can fix with no problem. I guess i should have said that.... it looks the exact same as my buddies 89-91 hatch i was actualy told today that it was pfi, programed fuel injected i though it was carbed..ops. Like i said the car turns over its just it wont stay running with out tapping the gas. I still cant find anything on the ecu code. I know how to read them just cant find a page.
Im only going to buy it if its something simple and not like the timing being off.....etc because i have a 97 200sx that i want to get on the road but i could use the cheap insurance/ no inspection thing since im in school and my refund check is buying it
Old 02-14-2012, 03:18 PM
97ser's Avatar
i actually told the guy to check the vacuum lines but he is set on a timing issue or something bad...
chprr
Honda Civic (2006 - 2015)
14
10-30-2022 11:20 AM
dingomel
Honda Civic (2016 - Current)
11-14-2017 11:20 AM
civicguy35
Honda Civic (2001 - 2005)
19
08-06-2016 01:08 PM
DJLikwid
03-08-2011 08:09 AM
Shaguar47
11
10-07-2009 06:18 AM
Quick Reply: 89-91 civic hatchback starting problems
