Rack & Pinion Power Steering Leak
Old 02-07-2012, 11:11 AM
ProjectOneTexas's Avatar
Default Rack & Pinion Power Steering Leak
i know there are several threads on this subject but none really answering my questions
i have a 1992 EX Sedan manual transmission
and my rack & pinion on the passenger side tie rod is leaking ps fluid ridiculously
my questions are:
1.if i remove all of the PS will this fix this too?
2.how safe and/or reliable is my rack & Pinion with that bad seal with no PS?
and i never had this problem until i lowered my car significantly from stock height
3.could that have anything to do with this leak or is that just completely a coincidence?
4.should i raise it back up and can raising it back up fix this problem as well?
i noticed a huge change in angle of the tie rod went from this -> / to this -> \
just curious any help is greatly appreciated
i also have pictures if they are needed and what not
Old 02-07-2012, 11:16 AM
kyden's Avatar
Default Re: Rack & Pinion Power Steering Leak
removing your p/s will not fix the problem, as you need fluid for the gears. raising it back up will not fix the problem either, as the seal is gone.
Old 02-07-2012, 11:23 AM
but if i remove the power steering it will stop leaking right? and still be functional? or withit goto crap on me if i do that?
Old 02-07-2012, 11:27 AM
Former User's Avatar
Replace the rack.
Old 02-07-2012, 11:53 AM
okay i will but i get paid in 2 weeks can i still drive this thing daily and be okay?
plikit
05-22-2008 10:29 AM
My JDM EJ8
05-18-2008 08:29 PM
Econo'Box
10-18-2006 06:14 PM
tres
09-22-2005 09:35 PM
Quick Reply: Rack & Pinion Power Steering Leak
