2010 Honda Civic Transmission
Old 01-21-2012, 12:50 PM
mafiadogg's Avatar
Default 2010 Honda Civic Transmission
Hi, I have a 2010 Honda Civic that has a problem with a shifting problem. Whenever I press on the gas, the car rev's but does not drive. After a little bit the transmission kicks in really hard into gear and then starts to drive. Same thing happens in reverse. The transmission takes a bit to kick into gear. The gears are basically lagging when they are supposed to shift. When they do shift, it feels like the transmission kicks the whole car. I have already replaced the transmission and the same problem is still there. What is wrong with the car? Anyone else have this problem?
Old 01-21-2012, 01:16 PM
DaveSi677's Avatar
Default Re: 2010 Honda Civic Transmission
Is this an auto or manual?
Old 01-21-2012, 08:17 PM
mafiadogg's Avatar
its an automatic.
Old 01-23-2012, 06:58 AM
bee guz's Avatar
If your fluid level is correct the transmission has some issues, possibly in the transmissions computer.
I would take it to a dealer and have it diagnosed asap, before you do more harm to it.
Old 01-23-2012, 09:21 AM
mafiadogg's Avatar
There is enough transmission fluid. I'm also thinking that it might have something to do with the computer. The transmission is new and should not have problems like this.
Old 01-24-2012, 06:17 AM
dtapia's Avatar
is their any codes stored or the D light flashing ?
Old 01-25-2012, 11:09 AM
mafiadogg's Avatar
YES! The D light does flash! Can you tell me whats wrong?
Old 01-25-2012, 12:03 PM
av911's Avatar
D flashing = Bring it in!!!
Old 01-25-2012, 03:49 PM
dtapia's Avatar
then the system needs to be scanned. most likely a pressure switch.
Old 01-25-2012, 04:32 PM
apexi_rsx's Avatar
when ur car is under warranty u should always take it to them when they will do it for free. the D light flashing is usually a transmission failure sign. its kinda like a misfire from the engine the CEL flashes instead. it may drive, it may not, but its limping for sure. so the trans will be limping for this instance
Old 02-05-2012, 07:12 PM
mafiadogg's Avatar
The car is in a certified transmission shop. Currently, they have not found the exact problem with the car..
Old 02-17-2012, 11:24 AM
koukou0o2's Avatar
sounds to me you need to add some tranny oil :D
smurf357
05-18-2016 04:16 PM
Vaymoon
03-02-2010 08:40 PM
stepwagon09
Transmission & Drivetrain
10-02-2009 11:04 AM
grpape
22
08-28-2008 05:38 AM
Quick Reply: 2010 Honda Civic Transmission
