power of main bearings SPOON
#26
Re: power of main bearings SPOON
Engineer is not necessary. You are building a unique engine. Experience is necessary. You can obtain experience from testing. You can obtain experience from people who build 11,000 RPM motors.
11,000 RPM motor is not normal. Normal engineering does not work. You can not know that 11,000 RPMs will make the parts resonate and vibrate. Only experience tells you how 11,000 RPMs affects the motor.
Will build on the principle of all means are good)))
#28
#29
He's joking.
Forget the Spoon blade, look at this about half way down the page:
http://www.erlperformance.com/produc...formance-parts
Rmember that you will need to dowel pin this in order for it to be of any use.
Jim Justice did mine.
#30
http://www.youtube.com/watch?v=0K2xT...eature=related
This shows the block blade alittle better.
#31
like i stated before it's just the block girdle that's what helps in 10k revs without blowing something up. Now that's why the F20c, K20's, and the famous f20b rev high without complications.
MHBb16CRX
05-14-2010 04:23 PM
