wheres is the egr valve?
Old 12-26-2011, 11:54 AM
greenskittle's Avatar
Default wheres is the egr valve?
d16y7 engine automatic 2000 honda civic lx. Cars runs weird at startup till it warms up. The check engine light popped on so i read it and says misfires in cyclinder 2 and 3 and possible fixes where dizzy cap witch i replaced like months ago and egr valve but i can find the egr valve to clean. Where is it located?
greenskittle is offline
Old 12-26-2011, 12:02 PM
exb18c1's Avatar
Default Re: wheres is the egr valve?
There is no EGR valve on this model(at least we don't have it in Canada).did you replaced only the cap?
exb18c1 is offline
Old 12-26-2011, 02:00 PM
replaced cap and rotor and new plugs and wires ngk
Old 12-26-2011, 02:06 PM
Wrona's Avatar
the Y7 doesn't have a EGR valve only the Y5 for the new d-series
Wrona is offline
Old 12-26-2011, 02:17 PM
humm so if theres no egr valve and the cap and rotor are new what would you thinks wrong? it starts up ruff and when its warm it runs perfect doesnt skip at all and theres no difference when driving or skipping at all
Old 12-26-2011, 03:22 PM
canadaek's Avatar
headgasket do a compression test
canadaek is offline
Old 12-26-2011, 07:36 PM
Nobody123's Avatar
What code(s) does it throw and how do you know the distributor cap and/or EGR valve would cause the code(s)?
Nobody123 is offline
Old 12-27-2011, 05:36 AM
kyden's Avatar
have you done plugs? number 1 cause of misfires on a civic.
kyden is offline
Old 12-27-2011, 09:19 AM
exb18c1's Avatar
agreed,compression test and leakdown tests would be the next thing to do.
exb18c1 is offline
Old 12-27-2011, 04:44 PM
Former User's Avatar
Have you done an ignition system tune up?
Former User is offline
Old 12-27-2011, 04:59 PM
a blown headgasket can cause this? codes where p0300 p0302 and p0303 if i recall correctly. The plugs wires dizzy cap and rotor where replaced 3-4 months ago and i checked the cap and rotor there was nothing wrong there.I just flushed the coolant last week and it was green with no oil in it.
Old 12-27-2011, 05:00 PM
i also pulled the plugs they where fine also
Old 12-28-2011, 05:31 AM
kyden's Avatar
what kind of plugs did you use?
kyden is offline
Old 12-28-2011, 11:51 AM
NGK V Power Spark Plug
Old 12-28-2011, 11:53 AM
used NGK wires also
Old 12-28-2011, 11:55 AM
Wrona's Avatar
have you checked ignition timing
Wrona is offline
Old 12-28-2011, 01:02 PM
H-T White Ops
NOFX's Avatar
Those are misfire codes for cylinders 2 and 3. P0300 is just a random misfire.
NOFX is offline
Old 12-28-2011, 03:36 PM
canadaek's Avatar
when my head gasket went it would run like crap for the first couple of minutes till it cleared itself out then would run fine .look for excesses smoke at start up (white)
canadaek is offline
Old 12-29-2011, 01:57 AM
it smokes alittle but it burns oil alittle and the smoke is very little and doesnt smell like anything like coolant im gonna have to get a compression check because it did this for 2 days and it went away now so im alittle confused on what it can really be and if its the head gasket its a very small leak.
Old 12-29-2011, 08:05 AM
exb18c1's Avatar
If it's intermittent it's not a head gasket.Check the IAC valve (it could be getting stuck intermittently)and clean the throttle body.
exb18c1 is offline
Old 12-30-2011, 12:08 AM
i"m gonna clean the iacv this weekend and throttle body
Old 02-19-2012, 12:17 AM
gsle3per03's Avatar
did that solve the problem?
i'm experiencing the same thing
gsle3per03 is offline
Old 02-19-2012, 02:52 AM
bukolkol's Avatar
are you losing coolant you might wanna do a pressure test.sound like a head gasket
bukolkol is offline
Old 07-26-2012, 01:39 AM
Demented98's Avatar
I hate people that don't post followup solution that fixed there problem
Demented98 is offline
knaup109
07-08-2017 04:01 PM
OldSchoolFool
04-20-2015 06:32 AM
Robotoyaki
01-01-2010 02:10 PM
Cyber ITR
11-21-2004 06:26 PM
Quick Reply: wheres is the egr valve?
