Speedometer randomly stops working
Old 12-05-2011, 11:23 AM
Freckles's Avatar
Default Speedometer randomly stops working
I'm pretty sure there's a thread about this somewhere, but I want specifics.
I have a 92 Civic hatch, and all of a sudden my Odometer randomly stops working, and randomly turns back on when it wants to. Sometimes when i take bumps it goes off too. Any ideas?
Old 12-05-2011, 11:24 AM
Former User's Avatar
Default Re: Odometer randomly stops working
Does the speedometer stop working when the odometer does?
kaiba's Avatar
Defected odo/speedometer or possible bad VSS(vehicle speed sensor)
Old 12-05-2011, 11:35 AM
Freckles's Avatar
I'm not an idiot when it comes to this **** but I'm confused with the two ( odometer / speedometer )
And it was working just fine.. for a while, and it randomly stops working all of a sudden.
Old 12-05-2011, 11:36 AM
Technical Hero
HondaPartsHero's Avatar
http://techauto.awardspace.com/vss.html
Old 12-05-2011, 11:38 AM
Originally Posted by Freckles
...but I'm confused with the two ( odometer / speedometer )
What you are saying here?
Old 12-05-2011, 11:40 AM
kaiba's Avatar
So you're saying your speedo works correctly but the odometer is faulty?
Old 12-05-2011, 11:41 AM
Freckles's Avatar
Sorry I mixed the two up. The speedometer randomly stops working, but the odometer works perfectly fine.
Old 12-05-2011, 11:44 AM
kaiba's Avatar
Most likely your speedometer gauge is defected. This is a common problem. Find yourself another cluster and swap it.
Old 12-05-2011, 11:47 AM
Freckles's Avatar
Alright. i'll try that. But also, my friend just bought himself a civic too, and the dude told him that the oxygen sensor is what's causing that to happen. idk if he's talking out of his ***, or it could be possible. And any suggestions on a nice cluster?
Old 12-05-2011, 11:51 AM
kaiba's Avatar
Any cluster from a Civic 92-95 will be plug and play(including the automatic). If your Civic doesn't have the factory tachometer. This might be a good time to look for that cluster.
Sorry can't comment on the o2 sensor issue.
Old 12-05-2011, 11:54 AM
Default Re: Speedometer randomly stops working
Title corrected.
Are you absolutely sure the odometer and tripmeter continue to work fine when the speedometer does not?
And no, a bad O2 sensor would have no effect on the speedometer.
Old 12-05-2011, 12:02 PM
Marvin1985's Avatar
To put this in dummy terms. Your MPH gauge randomly cuts out. I have exact same issue. I'm assuming it might be the speed sensor.
Old 12-05-2011, 12:08 PM
It's not a speed sensor problem if the odometer or tripmeter actually works all the time.
Old 12-05-2011, 12:28 PM
Freckles's Avatar
Odometer works perfectly fine, and so does tripmeter. only the speedometer doesn't work.. What could it be
Replace the speedometer or cluster.
Old 12-05-2011, 01:52 PM
angrysmileyface's Avatar
I had this problem, the circuit board went bad on the back my spedometer. I swapped one in from a used cluster, works fine didnt lose my milage or anything else. Kept the rest of my original gauges as well. I changed the VSS first being that it was 15$ and 20 minutes worth of time. Usually the culprit is a bad set of solder joints and being that I didnt want to spend time resoldering the entire circuit card, I just swapped it from another cluster that someone had botched a face covering install
Old 12-05-2011, 01:57 PM
Marvin1985's Avatar
I'm getting a new cluster myself since I need the rpm gauge anyway.
Old 12-05-2011, 04:55 PM
street_racer_271's Avatar
ive got clusters if anyone needs...
Old 10-18-2019, 10:57 AM
purple iris's Avatar
Do you still have any clusters I need one for '04 Honda Civic lt Sedan and how much are they
sLyBlAzNbBoI
05-28-2012 05:19 PM
daviss22
04-22-2012 09:19 AM
mr. biggles
04-11-2007 06:59 AM
Quick Reply: Speedometer randomly stops working
