CRV ENGINE PROBLEMS
CRV ENGINE PROBLEMS
Hi
I have 2002 Honda CRV Auto V tech, its done 138,000 miles and has full service history.
I took it to my local garage as the engine management light came on, and once you reached around 40mph the engine would miss, if you put a lot of revs on for example going up a hill, it also misfires. I believe the fault code is 12959 but not 100% sure, after 2 weeks my local garage can not sort the problem so have taken it to the Honda main dealer.
They have put it on their computer and its saying a problem with the v tech system, they wanted to know if its regularly serviced, told them yes, also wanted to know if its run low on oil, told them no, it has no leaks and hardly ever uses any oil.
They are wanting to change the oil & filter and clean other filters out, my Honda has a timing chain, worst case they are saying it might have skipped a tooth??? Had it going on 7 years and never had a problem with it, has anybody ever had anything like this and how did you deal with it? Any help would be great.
Re: CRV ENGINE PROBLEMS
Hi
Fondofhonda
07-14-2018 05:44 PM
bulldogbones
19
06-03-2013 06:57 AM
