50A igniton fuse keeps blowing
Old 12-01-2011, 11:10 AM
Teggerson's Avatar
Default 50A igniton fuse keeps blowing
Okay so I don't know if this could be my starter or my ignition switch.
So yesterday morning I went out start my car, and normally it cranks for like 5 seconds then starts up in the morning. This time when I cranked it, this burning metal smell came from under my steering wheel.
THE CAR TURNED OVER, and I drove it to work. When I left work like 5 hours later, turned the key to IION/Accessory dummy lights went on, but when I tried to crank it igniton fuse in the engine bay blew. Replaced it, did the same thing and it blew again.
Is there a way I can check to see if its my ignition switch or my starter?
Old 12-01-2011, 11:11 AM
Teggerson's Avatar
Default Re: 50A igniton fuse keeps blowing
Or is it possibly a short somewhere to the starter?
Old 12-02-2011, 01:52 PM
Teggerson's Avatar
BUMMPPPP
Old 12-02-2011, 04:39 PM
fcm
Old Fart
fcm's Avatar
The starter power itself is not fused, it could be a problem with the starter solenoid or wiring between the ign. switch and the solenoid, [possibly the starter relay or A/T gear position switch if it's an automatic, or the starter cut relay if you have OEM security].
I would start by doing a bypass jump, using a jumper with a 30A fuse in it, if fuse blows the solenoid is bad if not, leave the solenoid unplugged and unplug the ign. switch and do a continuity to ground test on the starter lead, [black/white], from both ends if it is a standard, either end if an auto.
If there is continuity to ground the starter lead has a short, if it is a standard and continuity is found at the ign. switch end, the problem is before the starter relay, if it is from the solenoid end the short is after the starter relay, if your car is an auto you will need to put shifter into a gear or unplug the A/T gear position switch and test starter lead from both ends to narrow down the location of the short. 94
Old 12-12-2011, 03:20 PM
H-T White Ops
NOFX's Avatar
Ever figure it out?
Old 12-19-2011, 12:04 AM
Teggerson's Avatar
Yes yes, I followed all my wires from ignition and it splits into my alarm. I check my alarm wiring and found a fuse blown on my alarm. Since my car has remote start and the alarm blew a fuse connecting to the wiring to my starter. My alarm kept causing my car to blow the 50a fuse and not start.
Old 10-23-2020, 12:36 PM
Raymond99's Avatar
Jow did you fix it?
bluenc-87
09-19-2016 11:47 AM
WarrenPeas
02-24-2013 11:29 AM
southernSCHEME
12-26-2009 04:23 PM
candyman206
02-05-2006 11:26 PM
Armed Ferret
08-10-2004 12:28 AM
Quick Reply: 50A igniton fuse keeps blowing
