Oil catch can with turbo application
Old 11-29-2011, 02:46 PM
  #26
digital sol's Avatar
Default Re: Oil catch can with turbo application
Originally Posted by jdmhondak9
thanks for the input, that is exacly what im doing, my can is simular but a little diffrent, i am runing it that way, what do you think about the line coming out of the can going to the turbo intake filter ?
what?
you want to run the line from the catch can to your intake filter?....why would you want vented crankcase pressure and blowby gasses/oil to be routed into your intake filter....
Id just run the lines off the back of the block to the can and call it a day. Empty the can once every blue moon and be done....most cans have a drain plug underneath, you can even put a nice little drain valve on the bottom so you dont have to remove the can to drain the fluids....just put something underneath to catch it...
Old 11-29-2011, 03:13 PM
  #27
jdmhondak9's Avatar
Originally Posted by digital sol
what?
so your saying to run a line off the box on the black of the block, the line for the pvc and rout the to the catch can, and the other line from the valve cover into the can. with no way to let the pressure exscape ?? there has to be a vent off the catch can. and yes the valve idea i planed on doing, makes draining alot easyier. but im not sure what your talking about just have one way pressure into a seal, oil catch can, one of the lines, the line on the top has to go to a force in wich it will create a vacume. ex the turbo, or the exhaust. and you wouldnt have two much oil and crap going in, thats what the can and the steel wool with the stainless steel kitchen scrub stuff is for, to filter the steam and send the filter air back to the turbo to keep the system contained. i figured it wouldnt be bad it would keep the system contained.
Old 11-29-2011, 03:36 PM
  #28
racebum's Avatar
you can vent between the filter and TB. it's kind of like the oem valve cover to intake tube idea. with a turbo it just has to be before the compressor. there's a slight positive to doing so in the vacuum created before the turbine. the downside is getting an oil film all over the cold side wheel
if i were going to do that i would black box to catch can and VC to intake tube. since the factory VC is baffled it traps a lot of the oil and minimal residue with make it through
Old 11-29-2011, 03:51 PM
  #29
jdmhondak9's Avatar
yeah thats true, only thing is, the valve cover was the one smoking real bad thats why i am doing the catch can in the first place, it didnt smoke for a while i just had one of those little filters on it and it was fine, but i had been planing on doing it and the time called. but as far as the gass's going into the cold side of the turbo.. i hope the catch can catchs lol.
Old 11-29-2011, 04:00 PM
  #30
Teglover101's Avatar
Got any links to Oil testing Company?
Old 11-29-2011, 04:27 PM
  #31
jdmhondak9's Avatar
umm.. no lol
Old 11-29-2011, 04:45 PM
  #32
racebum's Avatar
http://www.blackstone-labs.com/
right here. a standard analysis is $25
Old 11-29-2011, 04:54 PM
  #33
jdmhondak9's Avatar
why would i do that though ?
Old 11-29-2011, 07:42 PM
  #34
LightningTeg's Avatar
To tell you what your engine is doing
Old 11-29-2011, 07:51 PM
  #35
phat00civic's Avatar
That is who we used..
Old 11-29-2011, 09:20 PM
  #36
jdmhondak9's Avatar
yeah thats not a bad idea to do just to know, but still the smoke from the valve cover is a comon thing with any boosted hot rod, they smoke we just have to find ways to deal with it lol. 92 obd1 ! saftey only in MA babbyy
Old 11-29-2011, 09:52 PM
  #37
jdmhondak9's Avatar
Old 11-30-2011, 06:49 AM
  #38
kbouchard1092's Avatar
you realize oil analysis is $25?
No did not realize that, But i dont have a problem changing the oil that frequently...I change it maybe twice the whole year. If i drove it more frequently i would be more opted to look into something like this.
Old 12-01-2011, 04:23 PM
  #39
jdmhondak9's Avatar
the catch can came out awesome. Installed the can on the passenger shock tower ran a line into the can from the valve cover with a T fitting to the pvc valve, ran into the can, that has steel wool on the bottom of the can half way up, and on top of the steel wool i have a chunk of stainless steel aluminum kitchen scrubber, thicker material than the steel wool, to catch any fragments from the wool. On the cap to the catch can on the valve coming in with fumes, i ran a hose line from the valve to 3/4 down the can on the inside. to assure im getting the best filter system i can out of the wool and scruber. On the bottom of the can i have a drain valve to make draining the tank easyier. The valve i have at the top of the can to let the air out, comes out of the can, into a check valve that works oneway with a fine screen in the middle, to the ingen air filter, where i tapped a threaded 5/16 hose fitting on to, thats on the turbo. I want to post pictures but i cant figure out how to change my saved image to a URL ?? when i figure out how to do this i can post up some pictures
Old 12-01-2011, 05:00 PM
  #40
jdmhondak9's Avatar
[/IMG]
Old 12-01-2011, 05:02 PM
  #41
jdmhondak9's Avatar
Old 12-01-2011, 05:03 PM
  #42
jdmhondak9's Avatar
Old 12-01-2011, 05:05 PM
  #43
jdmhondak9's Avatar
Old 12-01-2011, 05:49 PM
  #44
jdmhondak9's Avatar
First step i did was takeing the cap off the can, taking the fittings out, and cleaning the metal shavings out of the can. I had to hog out the holes for the fittings i used but the ones the kit came with would work.
  #45
jdmhondak9's Avatar
[IMG][/IMG]
Old 12-01-2011, 05:51 PM
  #46
jdmhondak9's Avatar
Old 12-01-2011, 05:52 PM
  #47
jdmhondak9's Avatar
[IMG][/IMG]
Old 12-01-2011, 05:55 PM
  #48
jdmhondak9's Avatar
[IMG][/IMG]
[IMG][/IMG]
Old 12-01-2011, 06:03 PM
  #49
jdmhondak9's Avatar
Then i drilled the drain hole out 1/4 and put in the on/off valve
For steel wool, i put to pieces of steel wool in standing up in the can, and put the kitchen scrub material on the top of it, to block any fragments of the steel wool from getting through.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old 12-01-2011, 06:08 PM
  #50
jdmhondak9's Avatar
I used a little bit of high temp silicone on the cap, and used a screw driver to work the steel wool to make a slot for the 1/2inch briether hose coming in and going down the can.
[IMG][/IMG]
Quick Reply: Oil catch can with turbo application
