Pics of your tig torch setup :)
Old 11-11-2011, 12:19 PM
wade's Avatar
Default Pics of your tig torch setup :)
I ordered my new #9 torch with a large stubby gas lens and #12 cup, but the cup looks unlike most I have seen.
If anyone here uses the same setup I just listed, could you be kind enough to post a picture of your torch please
Old 11-12-2011, 09:11 AM
Agtronic's Avatar
Default Re: Pics of your tig torch setup :)
I'll post a pic later when I go to the shop. But post a pic of your setup, I'm curious to see.
Old 11-12-2011, 11:52 AM
RadekSkylark's Avatar
Here's is my setup, pretty much the same you'll have
SR9 torch with weldcraft large gas lens + #12 cup
When I first got that cup I was shocked :D It was huge... but now it seems normal, and everything smaller - tiny
Good luck!
Old 11-12-2011, 12:03 PM
HellaFab's Avatar
CK large diameter gas lense (1 1/8" iirc) on a WP #17 torch. air cooled.
I need to get some more lenses.... i cracked mine.
Old 11-12-2011, 05:33 PM
OG Fabricator
ToxicFabrication's Avatar
Wade, you already know mine, sent you pics twice! Haha
Old 11-12-2011, 07:55 PM
Glen_63's Avatar
Originally Posted by sdubfid
wp26 aircooled and wp20 watercooled
The insulator on your 26 isn't the right one, and your #20 looks weird too.
Old 11-13-2011, 02:40 AM
wade's Avatar
Thanks! I'm awaiting my insulator. Mine looks like Rades. How much are those clear lens setups?
Old 11-13-2011, 06:32 AM
HellaFab's Avatar
pretty $.
for the lense, insulator, cup and collet it was $80.
Old 11-13-2011, 06:33 AM
OG Fabricator
Those clear pyrex cups (gas savers) I have one, and used it a hand full of times. To get gas coverage comparable to a standard #12 cup I have the raise the regulator to around 40-55cfm. More like gas waster imo.
Old 11-13-2011, 10:30 AM
OG Fabricator
CRMB's Avatar
Most common torch we use is a pencil torch, the WT-20P.
Old 11-14-2011, 05:21 AM
HellaFab's Avatar
CRMB, i have not used a pencil torch before and have a question.... how does one HOLD the pencil torch? like a normal pencil or parallel to your forearm?
It would seem (without having used one) that the weight of the hose would be problematic when holding like a pencil without some overhead rigging to hold the weight of the hose.
I have one that came with my welder, but i have never bothered trying to hook it up.
Old 11-14-2011, 08:46 PM
Boosted_B_Series's Avatar
Hey Wade,
Here is mine, its a wp20, but its pretty much a watercooled version of a wp9. Uses the same front end parts.
It has a 25ft braided hose, zip up cover and #12 gas lens. I dig it, just need one more part and I'm watercooled.
Thanks for introducing me to the smaller wp9/20 and the braided rubber hoses. I like them alot better than the wp17 setup I am used to.
DK
Old 11-15-2011, 10:35 AM
OG Fabricator
CRMB's Avatar
You hold it like a pencil. I dont remember the cables being much of a concern but it has been more then a few years since I picked up a tig torch.
Old 11-15-2011, 02:53 PM
RickyLee53's Avatar
I found exactly the same thing. Waste of money.
You'll need forearms like popeye to hold the weight of the cable I would have thought.
Old 11-15-2011, 08:40 PM
9295EJ-t's Avatar
typical weapon of choice
Old 11-16-2011, 06:59 AM
OG Fabricator
russianvr4's Avatar
same exact setup i use and LOVE It!
Old 11-16-2011, 05:25 PM
AllMotrGoesSlwr's Avatar
I can't get a good hang of welding with a 12. It seems too wide for moving around tight spaces.
Old 11-16-2011, 05:38 PM
9295EJ-t's Avatar
but you can hang the tungsten out at least an inch making maneuvering super easy (as long as nothing is bumping the cup)
Old 11-16-2011, 07:48 PM
I understand that, but it seems like I am always clanking it into ****. I just can't hang with the big cups, man.
Old 11-16-2011, 08:51 PM
Took me some practice to get used to the large cup, now just every now an then I need to ditch the #12 to get into tight spots. A smaller torch has helped alot.
Old 11-16-2011, 11:06 PM
Luserkid's Avatar
My setups for everything but AL.
Old 11-17-2011, 09:59 AM
batboyvaj's Avatar
What are you guys using for your argon flow rates with the #12 cup?
Old 11-17-2011, 11:33 AM
Agtronic's Avatar
Nice setups!
It took me a little while to get used to the #12 also. At first it feels like you're welding with a shot glass at the end of your torch. It also takes little time to get a feel for the right gas flow rates. (True of any cup change).
I use a WP-17 with the regular gas lens and a #8 for anything that doesn't need to be super clean (AL, or SS that I will clean after welding). For SS pipe and tubing that needs to come out clean, I use the large gas lens with a #12 cup.
For gas flow, I use ~12 cfh for the small gas lens, or like ~20 when using more stick out, but it depends on the joint I'm welding, and where it's located etc ...
For the large gas lens, I usually always set it at ~20-22 cfh.
My torch has taken a beating and a half, I tend to break things when I get angry. Last time I whipped it against a chair and it hit the top of the chair back and bend into a U shape. I unbent it and it still works fine. But just recently I threw it down and the back-cap pulled out from the back and took the threads in the body out with it. So I need to get a replacement soon. Not sure if I want to get something different or not ...
Old 11-17-2011, 09:47 PM
I normally always set mine to 15 cfh. Excessive stick out, 20-25 cfh
Old 11-17-2011, 11:03 PM
I Deliver
EJAYATE's Avatar
Havent seen any one post this one. Wp-125w. I use a wp-20 sometimes too.
Quick Reply: Pics of your tig torch setup :)
