Quickie Dyno Comparison - Skunk2 Alpha vs. Toda Fakie
Old 10-31-2011, 10:24 AM
MikeySpec's Avatar
Default Quickie Dyno Comparison - Skunk2 Alpha vs. Toda Fakie
Been creepin around H-T lately...looks like the AM forum has definitely taken a dive.
Originally Posted by Mikeyspec
For those who follow our testing, you may have seen that the Toda Replica has done very well on our 2L Bseries engines. Being finally able to get a Skunk alpha header....we had to test it.
RedLine is Toda Rep
BlueLine is Skunk2 Alpha
Tested on the same day minutes apart. No matter where we moved vtec or played with a/f and timing we couldnt get rid of the midrange lumpiness. I'll go ahead and assume its due to the cyl. pairing. Either way it rocked out on the very top end. The quality is real nice and it fits really well.
Engine combo is an 85X89 @ 13ish:1 compression.
Portflow PR3 Head on Pro3's and a modified PerformerX.
Old 10-31-2011, 10:45 AM
jdmekay9's Avatar
Default Re: Quickie Dyno Comparison - Skunk2 Alpha vs. Toda Fakie
Good info!
Old 10-31-2011, 11:09 AM
mouab18c1's Avatar
Wow thats impressive. Thanks for sharing
Old 10-31-2011, 11:10 AM
dellas's Avatar
Nice!!
Was the retuned after the Skunk2 install?
Old 10-31-2011, 11:24 AM
koczeka's Avatar
what a miracle from the big PR machine again... ~10 years and only 5hp on the top, plus more bumpy curve (plus worse ground clearance) on a 2l vs a replica
THANKS
Old 10-31-2011, 12:09 PM
MikeySpec's Avatar
I personally think that anything off the shelf that can make power over an already stout combo is a good start. If i toyed around with cam gears and massaged the crossover a bit more i guarantee i can get rid of that dip. I've had similar things happen with other headers and i was able to work most of it out.
The only thing is that my main test subject is a stock ITR which i'll have results coming soon on...
We are testing
RMF narrow rep
Hytech small tube rep
SMSP rep
Toda Rep
Skunk alpha
The ground clearance really isnt all that bad at all on the Skunk, its got more ground clearance than a jdm 4-1 ITR header.
Old 10-31-2011, 01:02 PM
Fink29's Avatar
Replica vs. "Replica", looks good to me! Thanks again Mikey.
Old 10-31-2011, 01:41 PM
C_Rock77's Avatar
Yeah...like it was cruising in a car that drove off a cliff!
THANKS
I wouldn't call this coming from a big PR machine. Mikey doesn't have a dog in the fight, you know that.
The Toda has better clearance than the Alpha?
Old 10-31-2011, 01:48 PM
FlewByU352's Avatar
Wow I'm impressed! It was close with the Toda all the way up to the top end where it took over. A bit lumpy with the Alpha compared to the Toda but still impressive.
Old 10-31-2011, 03:22 PM
All Motor Mentor
00Red_SiR's Avatar
I'm pretty sure he was refering to Skunk2 and their header.
Old 10-31-2011, 03:36 PM
A Digital Frontier
dirtyharryhatch's Avatar
Always putting in work!
Old 10-31-2011, 03:39 PM
93egSLEEPER's Avatar
Where's Bisimoto??? good test Mikey
Old 10-31-2011, 06:56 PM
What would Chente do?
Louie's Avatar
I just picked up an alpha header so I was crossing my fingers it would do well before I clicked on the thread. Also going on a stockish R.
Old 10-31-2011, 08:46 PM
GagnarTheUnruly's Avatar
Looks like a winner from what I can tell. Sure it's going against a replica Toda but it's still a strong design and for an 'original' header from a major manufacturer that costs $400, it's hard to complain. It's nice to have the option of buying a solid inexpensive header that's not a knockoff.
Thanks for the test, and looking further to the rest.
Old 10-31-2011, 09:32 PM
koczeka's Avatar
and for the rest of the test
Old 10-31-2011, 09:49 PM
C_Rock77's Avatar
I realize to what he was referring...I was just under the impression he was implying that Mikey was testing FOR Skunk2.
Old 11-01-2011, 02:53 AM
N/A
Purpose Built
N/A's Avatar
Another good comparison
Deff should test against the rmf narrow/rep ASAP.
Old 11-01-2011, 03:09 AM
egb18c5's Avatar
nice test as always
Old 11-01-2011, 04:12 AM
92lx's Avatar
i am in the market for a new header and this info is helping out alot.
Old 11-01-2011, 08:24 AM
#1 Super Guy
94eg!'s Avatar
We are testing
RMF narrow rep
SMSP rep
Toda Rep
Skunk alpha
Are these going to be tuned or just bolted on? It would be very interesting to see each header run on an identical base-map (like phearable) vs each header with a mild tune. It would be a really simple way to double your testing results too.
I've got a stock 97 B18C R w/ a RMF narrow rep so I'm definitely pullin for that.
Old 11-01-2011, 09:51 AM
219DAdriver's Avatar
Jus got another hytech rep for the dd b16. curious to see if the numbers are goin to be identical/close to the other tri-y designed manifolds. especially since i'll be comin to you for a tune with a similar setup in a few months. except im considering the corn juice. *grabs popcorn and kicks feet up*
Old 11-02-2011, 03:41 AM
JayWest's Avatar
Good stuff Mikey
Definitely agree that anything that can extract even a little bit of power out of a setup that is nearly maxed out, is really a winner
Old 11-03-2011, 12:22 AM
mikesrex's Avatar
nice test it definitely answers one of the questions I had about these two headers. I'm trying to decide what to put on the CRX for the AMS class at IFO and was deciding between these two headers.
I wonder if the pairing of the Skunk2 helps it up top like that.
Old 11-03-2011, 09:47 AM
flesh199's Avatar
thx for your dyno testing mikey
Old 11-06-2011, 12:51 PM
vtibrazil's Avatar
I have a toda rep, and I has a rmf narrow rep before it. I have not been to the dyno yet since I stwitched to the toda rep but mid range feels way better.
Quick Reply: Quickie Dyno Comparison - Skunk2 Alpha vs. Toda Fakie
