Quickie Dyno Comparison - Skunk2 Alpha vs. Toda Fakie
Been creepin around H-T lately...looks like the AM forum has definitely taken a dive.
Originally Posted by Mikeyspec
For those who follow our testing, you may have seen that the Toda Replica has done very well on our 2L Bseries engines. Being finally able to get a Skunk alpha header....we had to test it.
http://i180.photobucket.com/albums/x...011_220720.jpg http://i180.photobucket.com/albums/x...011_220618.jpg http://i180.photobucket.com/albums/x...avsTodaRep.jpg RedLine is Toda Rep BlueLine is Skunk2 Alpha Tested on the same day minutes apart. No matter where we moved vtec or played with a/f and timing we couldnt get rid of the midrange lumpiness. I'll go ahead and assume its due to the cyl. pairing. Either way it rocked out on the very top end. The quality is real nice and it fits really well. Engine combo is an 85X89 @ 13ish:1 compression. Portflow PR3 Head on Pro3's and a modified PerformerX. |
Re: Quickie Dyno Comparison - Skunk2 Alpha vs. Toda Fakie
Good info!
Wow thats impressive. Thanks for sharing
Nice!!
Was the retuned after the Skunk2 install? |
:o what a miracle from the big PR machine again... ~10 years and only 5hp on the top, plus more bumpy curve (plus worse ground clearance) on a 2l vs a replica
THANKS |
I personally think that anything off the shelf that can make power over an already stout combo is a good start. If i toyed around with cam gears and massaged the crossover a bit more i guarantee i can get rid of that dip. I've had similar things happen with other headers and i was able to work most of it out.
The only thing is that my main test subject is a stock ITR which i'll have results coming soon on... We are testing RMF narrow rep Hytech small tube rep SMSP rep Toda Rep Skunk alpha The ground clearance really isnt all that bad at all on the Skunk, its got more ground clearance than a jdm 4-1 ITR header. |
Replica vs. "Replica", looks good to me! Thanks again Mikey.
Originally Posted by MikeySpec
(Post 46272061)
Originally Posted by koczeka
(Post 46272388)
THANKS The Toda has better clearance than the Alpha? |
Wow I'm impressed! It was close with the Toda all the way up to the top end where it took over. A bit lumpy with the Alpha compared to the Toda but still impressive.
Originally Posted by C_Rock77
(Post 46273222)
I wouldn't call this coming from a big PR machine. Mikey doesn't have a dog in the fight, you know that.
Always putting in work!
Where's Bisimoto??? :P good test Mikey
I just picked up an alpha header so I was crossing my fingers it would do well before I clicked on the thread. Also going on a stockish R.
Looks like a winner from what I can tell. Sure it's going against a replica Toda but it's still a strong design and for an 'original' header from a major manufacturer that costs $400, it's hard to complain. It's nice to have the option of buying a solid inexpensive header that's not a knockoff.
Thanks for the test, and looking further to the rest. |
Originally Posted by 00Red_SiR
(Post 46273836)
I'm pretty sure he was refering to Skunk2 and their header.
and :thumbup: for the rest of the test |
(Post 46273836)
Another good comparison :thumbup:
Deff should test against the rmf narrow/rep ASAP. |
nice test as always :thumbup:
i am in the market for a new header and this info is helping out alot.
(Post 46272676)
We are testing RMF narrow rep Hytech small tube rep SMSP rep Toda Rep Skunk alpha I've got a stock 97 B18C R w/ a RMF narrow rep so I'm definitely pullin for that. |
Jus got another hytech rep for the dd b16. curious to see if the numbers are goin to be identical/close to the other tri-y designed manifolds. especially since i'll be comin to you for a tune with a similar setup in a few months. except im considering the corn juice. *grabs popcorn and kicks feet up*
Good stuff Mikey
Definitely agree that anything that can extract even a little bit of power out of a setup that is nearly maxed out, is really a winner |
nice test it definitely answers one of the questions I had about these two headers. I'm trying to decide what to put on the CRX for the AMS class at IFO and was deciding between these two headers.
I wonder if the pairing of the Skunk2 helps it up top like that. |
thx for your dyno testing mikey
I have a toda rep, and I has a rmf narrow rep before it. I have not been to the dyno yet since I stwitched to the toda rep but mid range feels way better.
