Rear strut problems 2000 honda civic lx
Old 10-14-2011, 12:10 PM
greenskittle's Avatar
Default Rear strut problems 2000 honda civic lx
ok i installed some quick struts on my rear that i got off ebay.The problem is theres a rattling coming from both sides mostly when i hit small bumps.I even replaced the camber arms and trailing arms and they still rattle like a sob. i made sure everything was tight. Has anyone had this problem before? defective quick struts? or did i miss something and its lose? the sound comes from the top area as it was a bad mount? more of a rattly clunk. anything will be helpful because my next step is get some quick struts from advanced auto parts lol
Old 10-14-2011, 12:28 PM
The Grumpiest
grumblemarc's Avatar
Default Re: Rear strut problems 2000 honda civic lx
WTH are quick struts?
Old 10-15-2011, 12:54 AM
its the mount spring and strut pre assembled. you just swap out the old one for the entire new assembly saves you like 45mins and a chance to break your arm or face lol
Old 10-15-2011, 03:56 AM
Seagull Management
94EG8's Avatar
Pretty much what he said, it's a Monroe trade name. They're complete junk though. I'd go with a good quality shock like OEM, KYB, Koni or Tokico and reuse the stock springs, it's more work and takes longer but you'll get a better ride and they'll last a lot longer.
Old 10-15-2011, 05:24 PM
rhymeshark916's Avatar
You replaced the upper control arm and is it loose? Did you strip it? The two 14mm bolts? I stripped both bolts and it's rattling. I can hear it. So it's loose.
Old 10-16-2011, 09:47 AM
the bolts are not stripped at all and i replaced the camber arms theres no upper control arm in the rear
Old 10-16-2011, 09:53 AM
The Grumpiest
Maybe get a real suspension setup.
Old 10-16-2011, 10:22 AM
Master Detailer
98civdx's Avatar
Um, yes there are.
Those "camber arms" ARE THE UPPER CONTROL ARMS.
What else did you replace? Is the car lowered?
Old 10-19-2011, 10:38 PM
nah cars not lowered its a daily driver and theres no need for me to lower it. i think the mounts maybe are bad because the rattle comes from the top and its on small bumps only. i checked all the bolts there still tite.I replaced everything in the rear suspention but the lower control arms but the noise comes from the top so i think maybe i should pull out the entire strut assembly and take it apart and see whats going on
labradoofis
11-04-2009 05:58 AM
civic91
06-04-2009 11:24 AM
91bluehatch
04-28-2009 06:54 PM
SloCrxDx91
01-01-2006 12:22 PM
michaelpr
12-03-2003 06:18 PM
Quick Reply: Rear strut problems 2000 honda civic lx
