Integra SRS light on after hrg install
My fet hub(detatchable wheel) recently broke so I installed the hrg kit, unfortunatly with the hrg I had to remove all the srs stuff behind the wheel while my fet allowed everything to remain on there.
Now the light is stuck on, is there anyway around this, its not like I can reconnect the bulky srs stuff behind the wheel and let it hang, its too big...
1 Post
Re: Integra SRS light on after hrg install
No you unplugged the srs harness to install the aftermarket wheel and hub. Now you have to pull the gauge cluster and remove the bulb from the srs spot.
Well that stinks, i guess fet had there crap straight, ill just leave the light on
Could you give me a quick walk through please
Actually im going to try the resistor trick as i want my passenger airbag to work.
SLEEPER775
10-10-2007 02:45 PM
Rene M
10-11-2006 02:43 PM
servion
01-14-2002 01:54 PM
