2000 gsr p1456, clear code then flashes cyl 4 misfire
Old 09-16-2011, 06:18 AM
skuded's Avatar
Default 2000 gsr p1456, clear code then flashes cyl 4 misfire
its a 2000 gsr runs great, has a p1456 evap code, when i clear the code automatically the check engine light starts flashing code p0304 and stays flashing until i turn the car off, the car doesnt feel like its misfiring, i just replaced plugs to see if it helped and it didnt change, the ignition side seems like it has strong spark on all cylinders, and fuel pressure is within specs, need to know if anyone has run into this problem
coffeyface2000
02-07-2015 03:18 PM
mtbowen
11-24-2006 10:26 AM
JM Performance
12-19-2001 06:26 PM
Quick Reply: 2000 gsr p1456, clear code then flashes cyl 4 misfire
