Getting a code 45: any ideas?
Old Dec 19, 2001 | 08:25 AM
JM Performance's Avatar
Default Getting a code 45: any ideas?
I'm getting a code 45: System Too Lean or Too Rich malfunction in the fuel monitoring systems.
Anyone have any ideas? I'm guessing its my MF2 that needs to be tuned.
Old Dec 19, 2001 | 08:26 AM
MackSpeed-616's Avatar
Default Re: Getting a code 45: any ideas? (00SilverLS)
or you can get rid of it all together and get a REAL method of fuel delivery
Old Dec 19, 2001 | 08:28 AM
Default Re: Getting a code 45: any ideas? (TurboR616)
yeah, i could do that. Thanks for the amazing help!
Old Dec 19, 2001 | 08:30 AM
Flamenco-T's Avatar
if I am not mistaken, Arturbo once get that code, you might want to ask him what he did to solve it..
stan
Old Dec 19, 2001 | 08:33 AM
GSRacer's Avatar
New User
Default Re: Getting a code 45: any ideas? (Flamenco-T)
i was throwing the same code in my 2000 gsr. it seems that 2000 ecus' don't respond well to fuel changes. profileGSR was also throwing the same code. can anyone help?
Old Dec 19, 2001 | 08:38 AM
BowSeR's Avatar
New User
Default Re: Getting a code 45: any ideas? (GSRacer)
yeah 2000 ECU's are real sensitive to fuel changes. just be worried when that code comes up with 71-74 then u need to worry
Old Dec 19, 2001 | 08:39 AM
VaporTrail's Avatar
New User
it's simply means that your car is running too rich or too lean. That right there tells you exactly what you need to do. C'mon don't make me spell it out for you...
Old Dec 19, 2001 | 08:40 AM
Default Re: Getting a code 45: any ideas? (BowSeR)
is it a warning code or a limp code?
also, what can I do to prevent it? anything?
BuCU's Avatar
You never want to see the codes 71-74 ever. CYCLINDER MISFIRE is not good!!!
Old Dec 19, 2001 | 08:43 AM
VTC_CiViC's Avatar
Default Re: Getting a code 45: any ideas? (TeamElusive)
I've gotten a CEL 45 once or twice, don't fret. Reset the ECU and be happy till you get a standalone.
BoM's Avatar
BoM
check the plugs, are u running lean or rich?
when u find that out...then u do something to fix the problem
Old Dec 19, 2001 | 08:44 AM
Vapor, I know what it means, I'm asking whats causing it.
Also, what senses it? Primary O2?
Old Dec 19, 2001 | 08:46 AM
Flamenco-T's Avatar
I had a code 71 -74 alltogether all at once before, with Art's help, it turned out it was the FMU, it stays open at idle....dumping fuel when is not needed....
so if I were you I check the fmu first, find out when exactly does the CEL come on, driving time, idle time and etc, note the rpm as well...
then reset your battery, and by pass the fmu, don't go into boost, just drive around and try to match the same condition that you noted earlier when the CEL came on, and see if the CEL come on again....
if it only happend under boost, see if anyone hasd a FMU you can swap temporarily....
but again, this is based on what happened to me before, so HTH
stan
Old Dec 19, 2001 | 08:49 AM
You know what, i just realized that it only came on after boost. It has to be my mf2. I knew that damn thing wasn't tuned right from the factory.
Old Dec 19, 2001 | 01:57 PM
Arturbo's Avatar
Better than steak
25 Year Member
When I had that code it bothered me. I would reset the ECU and then a week later it would come back. I coundnt figure it out because it would come on at different times, for example after I gassed up. Another time while taking a long road trip. Then I decided to change out my plugs that had been in there for over 30kmiles and that solved it. Never got that code again.
art
Old Dec 19, 2001 | 04:38 PM
Default Re: Getting a code 45: any ideas? (Arturbo)
Art, that sounds like a good tip, but my plugs are brand new. I put them in w/ the turbo. I used the NGK BCPR7ES11, but haven't changed the gap yet. I'm not sure what the original gap on those are, but I was gunna set them to .030" tonight.
Oh, and btw, again I have no idea whats causing it. I thought it was that the MF2 was too rich during boost, but today I punched it the hardest I have yet, a full 2nd gear pull, and ....... no code!?
Old Dec 19, 2001 | 06:02 PM
Evil DOHC's Avatar
Hey 00 ls I still stand behind my word. THAT MF2 THING IS GARBAGE. I keep on warning u and u dont' listen. Your car is probable runnin so lean that the plugs are whiter than snow. Tunned or not, the mf2 is garbage. Seriously do yourself a favor and get a pump and a fmu, before u blow your motor.
EVIL
Old Dec 19, 2001 | 06:26 PM
Default Re: Getting a code 45: any ideas? (Evil GS-R)
Evil,
My car is not running lean! I checked my plugs....they look normal. I did full a second gear pull at .5bar and my EGT didn't even hit 800. and thats w/ the probe right after the head!
There are people who have tuned MF2s that run 9 and 12 psi daily fine.
::MUGEN::INTEGRA::RSi
Feb 11, 2005 08:19 AM
JM Performance
Dec 19, 2001 07:07 PM
Turbo EG6
Sep 9, 2001 11:07 PM
