CYP SENSOR?
Old 09-08-2011, 08:19 AM
Milby90ls's Avatar
Default CYP SENSOR?
HI I HAVE A CHECK ENGINE LIGHT ON AND I COUNTED BLINKS AND ITS THROWING CODE 9 CYP SENSOR WHAT IS THIS? HOW IMPORTANT IS IT? CAN I CLEAN IT OR IS IT A REPLACE ONLY ITEM?
Old 09-08-2011, 08:44 AM
Dannyx321's Avatar
Default Re: CYP SENSOR?
Its usually your distributor, but i would check other things out too.
I threw this code too and replace my dizzy which still didnt work, but then i swap to a different ecu and bam the light was gone.
Just make sure you try it before you buy it
Old 09-09-2011, 10:08 PM
anmolmark's Avatar
P1381 Cylinder Position (CYP) Sensor Intermittent Interruption
P1382 Cylinder Position (CYP) Sensor No Signal
Old 09-10-2011, 09:13 AM
mouab18c1's Avatar
Look up the diagnosis procedure on Google. It should help. I just had this stupid problem and replaced my distributor after testing everything.
lindylex
12
04-21-2015 11:46 PM
ed1le
07-17-2006 09:00 AM
quik89
11-30-2003 06:43 PM
Eluzion
06-20-2003 12:08 PM
TEGPOWER44
01-13-2003 04:00 PM
Quick Reply: CYP SENSOR?
