Old gas now missfiring
Old 07-27-2011, 10:40 PM
  #26
Master Detailer
98civdx's Avatar
Default Re: Old gas now missfiring
Originally Posted by NotAJDMFanBoy
Drain it and just run it in a lawnmower or a flamethrower. Don't throw too many additives in, but the HEET is a good idea, it'll absorb moisture.
He already ran all the crap gas threw it, he is on fresh fuel now.
But yes, run that **** threw your mower. Those things never seem to care.
Old 07-27-2011, 10:49 PM
  #27
altitude_19's Avatar
I didn't catch it: Does it run now (even badly)?
Old 07-28-2011, 05:21 AM
  #28
Jaydeep's Avatar
Car runs fine when cold engine. Once its warmed up wants to die unless I keep rpm above 2000.
Old 07-28-2011, 05:45 AM
  #29
The Grumpiest
grumblemarc's Avatar
Change the fuel filter.
Old 07-28-2011, 07:25 AM
  #30
turbodcxbro's Avatar
Bet you won't be doing that again... why in the hell would anyone put 5 year old gas in their car? I wouldn't put gas that old in my $200 weed eater...
Old 07-28-2011, 08:01 AM
  #31
Jaydeep's Avatar
I don't think its fuel filter since car runs good when its cold. Problem start when engine warms up.
Old 07-28-2011, 06:39 PM
  #32
How long does it take to warm up? Does your radiator fan kick on? If it runs cold, and not hot, it may be over-heating for some reason.
Old 07-29-2011, 05:16 AM
  #33
Jaydeep's Avatar
Car does not overheat. It takes normal time to warm up.
Old 07-29-2011, 05:43 AM
  #34
Former User's Avatar
Duplicate threads merged.
Old 08-01-2011, 08:12 AM
  #35
Jaydeep's Avatar
Took it to mechanic and compression test failed for cyl 3
Old 08-01-2011, 09:25 AM
  #36
Wrona's Avatar
Blown hg?
Old 08-01-2011, 12:36 PM
  #37
Jaydeep's Avatar
Originally Posted by Wrona
Blown hg?
Car is not overheating or leaking any fluid so I don't think its blown hg.
Old 08-01-2011, 01:41 PM
  #38
hyperblu's Avatar
Then you possibly have a bad valve seal on that cylinder...
Old 08-01-2011, 04:56 PM
  #39
What's the diagnosis technique to tell if it's the valve, or the hg? Just pull the head?
Old 08-01-2011, 04:59 PM
  #40
Cylinder leakdown test would be the best chance to distinguish.
Old 08-02-2011, 05:20 AM
  #41
Jaydeep's Avatar
Could you tell me how to do leakdown test?
Also I think there might be carbon built up. Is there any way I could clean it without taking out head?
Old 08-02-2011, 07:35 AM
  #42
hyperblu's Avatar
You need to either make or buy a leak down tester... You pressurize the cylinder with compressed air and turn the cam until all valves are closed... The guage will measure the amount of loss. You then listen at the intake,exhaust, and crank for the hissing sound... That is where you are losing compression. You can use seafoam on a dripper and let the intake slowly suck it in, but doing too much at once may ruin your piston rings if it's a higher mileage motor. You can also try adjusting your valve lash
Old 08-02-2011, 08:08 AM
  #43
Jaydeep's Avatar
Do you think if too much carbon is build up compression test would fail? Would seafoam work?
pepsi813
Honda CR-V & Element
05-19-2019 12:41 PM
hatch808
08-13-2004 05:53 PM
adaml2nv
06-06-2004 04:50 AM
E-Rok
12-26-2003 12:55 PM
sa1one
12-17-2003 10:16 PM
Quick Reply: Old gas now missfiring
