My B18C1 Engine Build/Assembly
Old 05-15-2012, 04:16 PM
  #2176
gringotegra's Avatar
Default Re: My B18C1 Engine Build/Assembly
Originally Posted by CaliforniaDad
I think I had them down to .019" if I remember right.
My eye gapper doesnt say that
I wish i didn't have to gap my ish down to .017 but i do with all stock ish lol
Old 05-15-2012, 09:01 PM
  #2177
No-Traction = Fun
CaliforniaDad's Avatar
Originally Posted by Whiterice-gsr
how are your brakes sounding now calidad? is it still really loud all the time or does it quiet down after awhile?
They like to be HOT, and then they are not as bad, but when cold yea they sound pretty loud. not a squeak but more like a semi truck sound brrrrrrrrrrrrrrr
Old 05-16-2012, 04:33 AM
  #2178
Flr Power's Avatar
The spark plugs look good. They may look lean because you are spraying water/methanol.
When the AEMEMS is properly setup, the boost does not change by more than 0.5 psi, cold, hot and in between.
I run the HP+ pads with the power slot disc and I get no noise at all. I wonder if the groove makes a difference. The only problem I get is when they get really hot then I get a little bit of vibration.
Old 05-16-2012, 04:41 AM
  #2179
rich7777's Avatar
Have any of you guys tried project mu hc+ pads? I have them on my car, there beyond amazing...
http://www.project-mu.co.jp/e/product/hc-plus.html
Old 05-16-2012, 04:47 AM
  #2180
Moderator
TheShodan's Avatar
That may mean that you've slightly warped them on a hot run at one time. It happens, even on slotted rotors.
Spraying the water meth should cause the ECU to add more fuel to run rich, not make the plugs "seem" lean at all. Even the Aquamist systems don't cause that. The AEM can only do so much correction from a cold day to a hot one. I'd change plugs, try it on a cold day again, and control boost manually as needed.
Old 05-16-2012, 05:01 AM
  #2181
tepid1's Avatar
I was getting some max boost spuddering last night at around 25psi, I could control it if I slightly let off the throttle. in turn the boost would drop ever so slightly by about .5 to 1 psi
Not sure if its some type of overboost spike or the AEM EMS is trying to correct it or what, but it is very annoying that I can't hold the pedal to the floor. I pulled my plugs right now to see whats going on in the combustion chambers. Pictures are far left cyl#4 -3 -2 - 1
Picture of plugs facing you cyl#4 is far right
You need to check your tune. You're getting some detonation on #3. I would also think that for your power level you would be on a heat range 7 plug.
Old 05-16-2012, 06:48 AM
  #2182
R.I.P. Mark
MRGRIM's Avatar
is it just me or does that look like compression leakage on #1
carbon on the thread all the way to the washer and seat
Old 05-16-2012, 06:56 AM
  #2183
No-Traction = Fun
Well I swapped out the plugs and went for a full boost sprint and no high boost hesitation now. So I'm guessing the plugs were tired. That set was about 3 months old. Also the heat range on the plug im using is an 8, stock is a 6.
Old 05-16-2012, 07:02 AM
  #2184
LightningTeg's Avatar
I wouldnt use Iridiums but thats just me
Old 05-16-2012, 08:01 AM
  #2185
Moderator
TheShodan's Avatar
Hmm.. I love the iridiums. For me, they've lasted longer than the standard 8 heat range, and are still resistor-oriented plugs.
Old 05-16-2012, 07:13 PM
  #2186
Turbo-LS's Avatar
Still havent fabbed up a mount for my camera in my car but , sorry for posting this in your thred but several peopel in here asked for one
Shitty video really quick this evening on my iphone. 3rd gear pull hit boost cut for some reason you can hear it cut out then rip 4th gear a little but came up on that mercedes quick LOL
Old 05-18-2012, 11:49 AM
  #2187
No-Traction = Fun
Hey MAC, do you think I can spool this sucker up or what?
Old 05-18-2012, 12:06 PM
  #2188
Moderator
TheShodan's Avatar
Hahaha.. Yeah.. I think it'll spool "quick"... Like.. if you start running the car today, it'll reach maximum pressure in about a week.
Old 05-18-2012, 12:16 PM
  #2189
kbouchard1092's Avatar
That thing has more displacement then the motor! lol
I think you should give the coil a nice wrinkle coating! Interesting location i like it.
Old 05-18-2012, 01:51 PM
  #2190
rich7777's Avatar
Thanks Calidad, i nearly died from choking on my drink after seeing that hahaha. Get that baby on !!!
Where the hell did you find it BTW ?? Try making something cool out of it like this
http://www.youtube.com/watch?v=BZoymnZRBVc
P.S. Mac, have you ever made a homemade jet engine like this ?
Old 05-18-2012, 05:33 PM
  #2191
When I get a house, I will do this!
Old 05-18-2012, 06:49 PM
  #2192
hondad6's Avatar
Use a smaller turbo to spool that one then another smaller one to spool that one and maybe it wont take a week. Maybe a day? lol that would make a great jet engine for a go-kart put wings and a tail and you got a plane.
Old 05-18-2012, 07:02 PM
  #2193
No-Traction = Fun
hahaha..yeah It came off a running diesel truck. The turbo has no shaft play and spins free. It a Garrett Turbo. Mac cleaned up would it be worth anything?
Old 05-18-2012, 07:33 PM
  #2194
No-Traction = Fun
Well sad news people!! Today I was driving into work on the fwy and decided to break off a street bike in 4th gear. I boosted all the way thru 4th, pulled away from him like crazy then went into 5th and just coasted in 5th back down to normal speed. When when I went to give it gas again it felt funny like a misfire, but oil temp EGT and water temp were all normal. No funny smells no smoke. So I pulled off the fwy and it was for sure missing. I called the wife and had her bring me some tools. I pulled out the 3 day old plugs and this is what I found. The bad one is Cyl#3
Old 05-18-2012, 09:16 PM
  #2195
Khnemu's Avatar
Wow... CaliDad you are going through some bullshit with that car. I know how it feels, I'm going through the same with my brother's car I built.
Old 05-18-2012, 09:40 PM
  #2196
No-Traction = Fun
Looks like the water meth injection was not switched on. So I'm guessing it burned up the #3 plug. I did a compression test and #3 has no compression. So I'm betting a bent valve too.
Old 05-18-2012, 09:49 PM
  #2197
vwbased's Avatar
have a nice night
Old 05-18-2012, 09:55 PM
  #2198
vwbased's Avatar
have a nice day
Old 05-18-2012, 11:52 PM
  #2199
rich7777's Avatar
O **** ! it sounds like piston no.3 has let go Calidad (not a valve). You need to pull the head and check. Hopefully its just the ringlandings that have let go (and not a hole straight through the piston). Either way, i'm sorry to say the lot will probably need stripping down and inspecting. Like vwbased says, if pieces of piston have gone through the bottom end then they'll take everything out they come in contact with i.e bearings, crank, ect...
You need to find out why that AEM water/weth kit wasn't on. If its not your fault, then it SHOULD NOT be you paying for the damage.
Good luck, and i hope things work out well.
Old 05-19-2012, 12:12 AM
  #2200
rich7777's Avatar
Get one of these to http://tunertools.com/proddetail.asp?prod=TXS-KNOCK
Get your machine shop to machine you up a adapter made from stainless steel which screws into the stock knock sensor port (as you can't fit the same sized bolt through the donut Bosch sensor). Just ditch the stock knock sensor for good, its obviously not doing anything.
This way you can manuely control things instead of relying on a dumb EMS to do it for you.
Quick Reply: My B18C1 Engine Build/Assembly
