My B18C1 Engine Build/Assembly
Old 06-27-2012, 10:37 AM
  #2501
hondad6's Avatar
Default Re: My B18C1 Engine Build/Assembly
aeok18109 if you stick to threads like this one you will be good. Just remember there are a lot of flamers, and to ignore them. they are not worth the electricity to post a response to.
Old 06-27-2012, 06:33 PM
  #2502
EK9
Dc4LsTeG's Avatar
Calidad I looked through your thread again and couldnt seem to find it. Do you have a pic of exactly how you had the meth injection hooked up the first time
Old 06-27-2012, 10:08 PM
  #2503
turboda4dr's Avatar
Originally Posted by wantboost
100% methanol will not cool down as much as a mix with water or 100% water using the same nozzle, since you lose some of the cooling abilities of the water and the methanol burns faster than it lowers IAT's
Methanol is a fuel, it makes the AFR richer
there are many inherent problems with running 100% methanol, namely safety as it boils at 148F. but that aside, you will lose a good amount of torque generated by the steam effect on the power stroke of the engine cycle leading to more torque. (Same principle that Steam engines were designed around) . Also at 100% methanol you are basically running a dual fuel engine.
Just be careful around the DOT with 100% methanol, if they ask tell them its 50/50. Otherwise tell them its HAZMAT class ORM-D, some of them love to bust your stones, as it has a quite distinct smell. Otherwise you can get a good fine for transporting a Combustible liquid, and corrosive without proper documents. IT IS ILLEGAL TO TRANSPORT (YES EVEN RUN IN YOUR CAR ON PUBLIC STREETS) METHANOL WITH A CONCENTRATION GREATER THAN 50% WITHOUT HAZMAT DOCUMENTATION.
Not to mention it chews through cheap plastic lines and on hot days when under hood temps get into the 150s it evaporates inside the line to the nozzle and can actually force its way past the nozzle causing fueling issues. Plus when running 100% meth with injection you need to be sure your tune is rock solid and that you have some sort of fail safe on the injection system so that if flow rates drop even the slightest bit it will shut down the pump and revert the ecu to a safe tune.
I've also see people running 100% meth for injection burn their cars to the ground (namely rx-7s but hey lol) since methanol burns with an invisible flame you won't know that anything is going wrong until its too late
thanks for the info
Old 06-27-2012, 10:20 PM
  #2504
Who is Mr Robot?
wantboost's Avatar
No problem. Just don't want to see you get in trouble or potentially get injured because of an accident with pure methanol. The water makes methanol stable since it dilutes it down. It also lowers its flash point and evaporation point
Old 06-28-2012, 07:18 AM
  #2505
No-Traction = Fun
CaliforniaDad's Avatar
I had it mounted about6" before the throttle body, in the charge pipe.
Old 07-01-2012, 03:46 PM
  #2506
No-Traction = Fun
Okay well, I put my bottom end together and here is what im at now.
Main bearing clearance
1. .0016
2. .0015
3. .0016
4. .0016
5. .0015
Rod bearing clearance
1. .0015
2. .0015
3. .0015
4. .0015
Ring end gap
Top ring .019
2nd ring .023
Oil ring .020
Old 07-01-2012, 03:55 PM
  #2507
dcmatt's Avatar
Thats a good bit tighter then the last bottomend isn't it?
Old 07-01-2012, 06:28 PM
  #2508
No-Traction = Fun
yes it sure is!!
Old 07-01-2012, 07:27 PM
  #2509
dcmatt's Avatar
Did something change your mind as far as what clearances you wanted this time?
Old 07-01-2012, 09:35 PM
  #2510
gringotegra's Avatar
1. .0016
2. .0015
3. .0016
4. .0016
5. .0015
1. .0015
2. .0015
3. .0015
4. .0015
Ring end gap
Top ring .019
2nd ring .023
Oil ring .020
I would have gone a bit looser than that on the main/rods....
Old 07-02-2012, 02:38 AM
  #2511
tepid1's Avatar
I hope you plan to run some light oil, CaliDad.
Old 07-02-2012, 02:56 AM
  #2512
rich7777's Avatar
And keep those oil temps under strict control
I'd image a set of either pink or red OEM bearings would land him somewhere more reasonable..
Old 07-02-2012, 05:39 AM
  #2513
Turbo-LS's Avatar
When I assembled my bottom end my tolerences were about the same on the mains and.001 more on the rods with acl duraglides. once the coating wears off on the bearnig they loosened up to a more comfortable spec. I run 10w30 oil in my ride. Now if its oem bearings id go lighter on the oil
Old 07-02-2012, 06:56 AM
  #2514
cruizinmax's Avatar
Ummm, I don't think the coating should "wear" off the bearings at any point...
http://www.mototuneusa.com/power_new...ular_logic.htm
Old 07-02-2012, 08:48 AM
  #2515
Gunmetal_B20_Hatch's Avatar
I had very similar tolerances when I built my engine w/ ACL Race bearings. I ended up running 10w-30 oil. Rechecked bearings after 1000 miles and they show no signs of unusual wear. Youre good to go.
Old 07-02-2012, 10:43 AM
  #2516
This.
Old 07-03-2012, 07:06 AM
  #2517
No-Traction = Fun
I'm running ACL race bearings, The rod bearings are the HX series so they have the extra .001 clearance. The mains are ACL race as well. I plan on running the 5-40wt Torco SR1 oil after break-in. My last build I was running the same exact bearings and when I tore down the engine the bearings looked great!! So I'm going with what I know worked.
Old 07-03-2012, 07:51 AM
  #2518
Moderator
TheShodan's Avatar
Looks like you're good to go.. I am a little curious on how you came to your decision on oil. I thought you were originally going to use 10W30 VR-1 "Blue" oil. what changed your mind?
Old 07-03-2012, 01:05 PM
  #2519
Flr Power's Avatar
Since Calidad lives in a hot climate, it would be better to use 10w30 or 10w40. 5w oil should be used when the outside temperature goes below 5 degree F.
Old 07-03-2012, 02:42 PM
  #2520
Moderator
TheShodan's Avatar
I'm wondering how the oil temps are with his current oil cooler.... meaning, perhaps it should have some open access to air by way of ducting or something. Calidad has it in the right spot and orientation.. I'm strictly looking at access to fresh air.. not the cooler itself.
So what we have now for changes for this one is:
-9.2:1 Wiseco Piston
-reconfigured direct port meth/water injection at 80/20 mix
-Injectors? (I wasn't sure about this)
-Possibly larger meth/water tank? (I know it was mentioned by again, not confirmed)
-fresh head, valvesprings retainers
-GSC T1 cams - YIPPEEE!!
Old 07-04-2012, 09:48 PM
  #2521
g0at's Avatar
How's the wrinkle paint holding on your intercooler piping Calidad? I'm looking at doing a similar thing. Any chipping, flaking?
Old 07-05-2012, 05:05 AM
  #2522
Turbo-LS's Avatar
As long as you properly prep the surface the paint wil adhear and stick and not flake off. Painting is mostly about the prep before hand and then knowing how to spray. Thin light coats dont try to completely cover in one coat. Sand the surface and your golden.
Old 07-05-2012, 09:19 AM
  #2523
EK9
Dc4LsTeG's Avatar
Wondering the same thing
Any recommendations on what grit to sand with? Should I primer it before I paint it?
Old 07-07-2012, 06:46 AM
  #2524
No-Traction = Fun
ill post updates in a few, on vacation right now. be back tomorrow
Old 07-07-2012, 08:24 AM
  #2525
Turbo-LS's Avatar
I'm assuming aluminum piping? I would sand it with 180 then a good quality metal primer then sand with 220 lightly to smooth it out and then apply multiple light coats with 5-10 minutes between coats until a good coverage.
Quick Reply: My B18C1 Engine Build/Assembly
