Civic shifts hard
Old 06-23-2011, 02:01 PM
Jonathannx2's Avatar
Default Civic shifts hard
I have a 1994 Civic with a B20b swap. Sometimes the car gets really hard to shift and when it is in gear it seems as if the clutch is not fully pressed in when it really is. The clutch does not slip though. Would this be a clutch master cylinder or slave cylinder issue? Thanks in advance.
Old 06-23-2011, 08:05 PM
Default Re: Civic shifts hard
bump
Old 06-23-2011, 08:59 PM
Blacknight117's Avatar
Check both cylinders for any leaks, and also check the shift linkage as well, it may be loose or worn. Check the obvious too, the tranny fluid.
Old 06-23-2011, 09:08 PM
clutch master cylinder behind the clutch pedal is like damp with some gooey stuff but not like dripping.
Old 06-24-2011, 11:02 AM
bump
Old 06-24-2011, 11:47 AM
The Grumpiest
grumblemarc's Avatar
Does that sound normal to you?
Old 06-24-2011, 11:59 AM
No. But I don't know if that is necessarily the cause of the problem. Is it?
Old 06-24-2011, 12:01 PM
The Grumpiest
Leaking doesn't necessarily have to be dripping.
Old 06-24-2011, 12:03 PM
The Grumpiest
Also. Check the shifter bushings & linkage.
Old 06-24-2011, 12:12 PM
Alright thanks!
kinoy12
Acura TSX
12-01-2015 10:13 AM
jdm_phunk
02-27-2011 05:17 PM
Nuttynutnut
05-29-2009 06:04 PM
PearlBlueType-S
20
03-06-2006 11:10 PM
976
09-15-2001 10:41 PM
Quick Reply: Civic shifts hard
