P1705 PLEASE HELP!
Old 05-06-2011, 09:08 AM
CivicSweetie01's Avatar
Icon3 P1705 PLEASE HELP!
My car was acting just fine.
Then my check engine light comes on.
My car was in Drive, and the d starts blinking, but now the D3 light is on as if it was in d3.
I stop the car and put it in park, and the D is still blinking.
New tranny was put in it before I bought the car 10,000 miles ago.
Any suggestions on what I need to do?
I can't ever get honda parts around here, so I am going to have to order them somewhere.
PLEASE give me GOOD advice on what I should do.
Old 05-06-2011, 09:26 AM
lazlong's Avatar
Default Re: P1705 PLEASE HELP!
P1705= transmission range switch circuit malfunction.
Post #11: https://honda-tech.com/forums/showthread.php?p=43071329
Old 05-06-2011, 10:12 AM
I don't have technology to test it.
I don't have the money for Honda to test it.
I'm sure I have money for the parts, but where to get it?
Ahhh. this is just not my week >.< Thanks for your post
Old 05-06-2011, 10:48 AM
lazlong's Avatar
Test to see whether it's the switch simply by unhooking the connector and turning on the ignition. But if you want to just buy the switch: http://www.hondapartscheap.com/southbay/jsp/home.jsp Look under "AT RIGHT SIDE COVER ".
*Edited 'cause I was probably a little harsh.
Old 05-06-2011, 03:04 PM
okay thanks, and yes i have been searching all day on this. just a lot of cluster. thank you again.
Old 05-18-2011, 08:33 AM
Icon6 Re: P1705 PLEASE HELP!
It was my neutral safety switch.
I got that put on.
Then, found out that the smoke coming from my hood wasnt the thermostat housing that I had changed, but a crack in my radiator. Now, waiting on the radiator to get here to change that out.
When I looked on carfax before i got the car, nothing showed up. I checked it the other day. and there is 24 reports on my car... yipes... too bad i can't afford to find out what they all say... lol.
I know now, that is had been in a wreck, because when I was vaccuming it out i found glass in the seat. and my boyfriend pointed out a spot in the door that they didn't repaint....
So many problems... and now, i also found that the plastic cover in my cam shaft is leaking oil?? what is this and how can I fix it if anyone knows.
Old 05-18-2011, 09:10 AM
Plead da Fif
It Wasn't Me's Avatar
Are you referring to the plastic end plug? It's easy to replace, but it's best to remove the valve cover and work from inside.
I've heard of people just prying the old one out with a screwdriver, but you run the risk of braking one of the plug tabs off and having fall into the head while removing the old one.
Also, make sure to apply a little bit of oil (preferably fresh) to the seal before you install the plug.
Old 05-18-2011, 08:33 PM
it was the neutral safety switch the plug. I got the part and put it on. Light went off. That part is fine.
Old 05-18-2011, 08:38 PM
Plead da Fif
You said, in your last post..
That's what I was asking about.
What "plastic cover" are you talking about? There is no plastic cover for the camshaft, but there is a plastic end plug / seal.
Old 05-18-2011, 08:45 PM
yeah. it's at the end. so i guess it is the plugs. they are plastic. sorry. I'm new to all of this... i'm learning a lot as i go. bear with me.
Old 05-18-2011, 08:47 PM
Plead da Fif
No problem. It happens.
Old 05-18-2011, 08:50 PM
I will post more when I figure some more out on everything. It got late, I'm hoping this all works out in the end.... Single mother on very small budget... Hard Hard Hard dealing with a car that I can't afford to take to the shop >.<
Thanks for your nice and helpful posts.
Old 05-18-2011, 09:08 PM
lazlong's Avatar
@ CivicSweetie: If you can, pictures always help.
Old 07-15-2011, 10:20 AM
honda v6's Avatar
Icon2 Re: P1705 PLEASE HELP!
i had the same problem on my honda accord all if u just put a security sistem in your car have them disconect the kill switch relay and reset the ecu and it will all go away
Last edited by honda v6; 07-15-2011 at 10:23 AM. Reason: forgot to anwer the question
92f22a6
03-11-2014 08:54 AM
white98gs-r
01-08-2012 09:33 PM
Mavi87
08-25-2010 12:16 PM
globy123
06-02-2007 07:09 AM
Quick Reply: P1705 PLEASE HELP!
