Anyone know how to install A/C Receiver Dryer?!
Old 05-02-2011, 08:45 PM
hcs1jimmy's Avatar
Default Anyone know how to install A/C Receiver Dryer?!
So, I was told that if I replace my a/c compressor that I also need to replace my receiver dryer and do an evacuation along with a recharge. Is that right? If so...is there any precautions or anything I need to know before replacing my receiver dryer, like do I need to do an evacuation before I install it or after, or any special way to replace it? I am just curious as I am going to try to replace it tomorrow. Let me know if you have any advice. Thanks!
Old 05-02-2011, 08:51 PM
Former User's Avatar
Default Re: Anyone know how to install A/C Receiver Dryer?!
What car?
When a compressor fails, it can generate metal debris that can cause the A/C system to fail again. Therefore, it would be prudent to flush the system, replace the receiver/dryer, evacuate for at least a few hours, leak test overnight, and then recharge with oil and refrigerant.
Linked's Avatar
you need to recover all the refridgerent from the system before removing your old reciever drier
if there isnt any in the system because the system was open to the atmosphere, then you can just unbolt the receiver drier
Old 05-02-2011, 08:54 PM
hcs1jimmy's Avatar
It's for a 95 civic. The system was open for awhile, but I'm not sure if there was still refridgerent in the system still or not.
Old 05-02-2011, 08:57 PM
Linked's Avatar
like ron said before, was there any problems with the system before?
why was the system open?
and no there wouldnt be anymore refrigerant in the system anymore
Old 05-02-2011, 09:01 PM
hcs1jimmy's Avatar
Well, the compressor clutch went out on the old compressor so I wrapped the lines until I could get a compressor again.
Old 05-02-2011, 09:10 PM
Linked's Avatar
if you only replaced the compressor and wrapped the lines
then yes, you wouldnt have any refrigerant in the system, and can install the receiver drier
after you would evacuate the system and pull it into a deep vacuum. alot of AC service carts would hold vacuum for ~20 minutes.
after it confirms the system can hold a vacuum then there shouldnt be any leaks and they'll charge it.
you need to make sure to alert whoever is charging your system that you replaced your compressor, so they can recharge the right amount of oil into the system.
Old 05-02-2011, 09:14 PM
hcs1jimmy's Avatar
does it matter if it is a used compressor? I mean, as far as how much oil they put in? Also, do you know about how much (on average) a shop will charge to do all that?
Old 05-02-2011, 09:20 PM
If only the compressor clutch was bad, why replace the entire compressor? And it's possible to replace the clutch without disconnecting the A/C lines, though it's too late for that now.
Old 05-02-2011, 09:22 PM
Linked's Avatar
i dont know how much a shop would charge to charge your system, best bet is to call your local shop and ask (i wouldnt recommend a low quality shop with ac work though, they tend to only have one ac cart and will reuse unrecycled refrigerant)
and since the compressor is used, you run the risk of having contaminants in the compressor and also metal shavings that can clog the system
the best route to take at that time would be to assemble everything, install an inline filter on the highside right after the compressor then flush the system
Old 05-02-2011, 09:23 PM
hcs1jimmy's Avatar
oh i just didn't want to mess with replacing it plus my buddy just gave me his perfectly good compressor.
Old 05-02-2011, 09:27 PM
Linked's Avatar
describe the compressor, you got it straight out of his car while it was working? or he had it laying around?
Old 05-02-2011, 09:35 PM
hcs1jimmy's Avatar
ya straight out of his car.
RowenaH
12-08-2018 02:38 PM
dem0nk1d
07-21-2011 09:06 PM
herrgolf
21
07-16-2011 08:31 PM
critter49er
Honda Civic (2001 - 2005)
05-29-2008 09:30 AM
redeg61987
13
09-19-2006 06:39 PM
Quick Reply: Anyone know how to install A/C Receiver Dryer?!
