Clutch making a clicking noise... HELP!!!!!
Old 09-29-2002, 11:38 AM
acatak's Avatar
Default Clutch making a clicking noise... HELP!!!!!
For the past couple of months, my clutch started making a squeaking noise whn I push it in. The other day, it started making a clicking noise when I let off the clutch. It is just one click about halfway when im letting off the clutch. It does it whether im in gear or just in neutral. Anyone know what this is??? Maybe I have to lubricate something? Thanks for any help
Old 09-29-2002, 11:39 AM
bboychris's Avatar
Default Re: Clutch making a clicking noise... HELP!!!!! (acatak)
that happend me about 3 days ago it keeps squeeking, i have no idea either hopefully someone will respond that can help me also
Old 09-29-2002, 12:14 PM
WiggiE's Avatar
Default Re: Clutch making a clicking noise... HELP!!!!! (b18c-one)
I have the same problem. I think my clutch is on it's way out.
Old 09-29-2002, 01:51 PM
mattL's Avatar
its common, mine does it all the time. sometimes it squeaks sometimes it pops sometimes it clicks, the best remedy is turning your music up. Some people say its the master cyl, check for any fluid at the top of the clutch pedal. i know mines fine and its not your clutch going out, mine did it before and after the new clutch. the funny thing is that it will just stop and then start again.
Old 09-29-2002, 05:54 PM
acatak's Avatar
Default Re: Clutch making a clicking noise... HELP!!!!! (mattL)
Yea, its def not the clutch going. Mine still grabs fine. Im prob gonna bring it in to my mechanic soon. Ill let you guys kno what he says
Old 09-29-2002, 07:58 PM
integraautox's Avatar
fill me in to when i let my clutch out slowly going around 30 mph into 2nd it squeks really loud
Old 09-29-2002, 08:48 PM
T-sohctec's Avatar
Default Re: Clutch making a clicking noise... HELP!!!!! (integraautox)
I'm prretty sure all you guys are hearing your throw out bearing. your going to need to replace it. This does require you to seperate the bell housing i.e. pulling your engine.
hope this helps, and for any of you that do not have a lift or a hoist, hope that I am wrong
Good luck
Old 09-29-2002, 11:00 PM
vtec.dc2's Avatar
well.. maybe not that bad.. mine been doing that for past 10-15K miles - i been taking it easy.. but its been getting worse... much worse recently - i'm getting it replaced soon...
maybe this might help: https://honda-tech.com/zerothread?id=179021
[Modified by vtec.dc2, 3:04 AM 9/30/2002]
Old 09-30-2002, 01:32 AM
ragejed's Avatar
Default Re: Clutch making a clicking noise... HELP!!!!! (vtec.dc2)
Ive had an act hdss clutch in for the past 3k miles. it makes a click when letting off the clutch sometimes. I doubt mine is on the way out.
Old 09-30-2002, 06:56 AM
SmokeU's Avatar
Same here.
Old 09-30-2002, 07:01 AM
eh-D's Avatar
Default Re: Clutch making a clicking noise... HELP!!!!! (You Know Me)
Your problems are most likely from the clutch release bearing. The life of said bearing is dependent on your driving habits(or whoever drives your car). My OE clutch had plenty of disk left, but the bearing was toast thanks to the previous owner.
Also the cluch pedal itself can make some noise if you don't have it properly adjusted. I found out mine was allowing the piston to extend too far, fixed that and no more pedal noises. But a noise coming from under your foot, and a noise coming from under the hood are a world apart. Try looking for info on a throwout bearing or release bearing.
Old 09-30-2002, 06:24 PM
acatak's Avatar
Default Re: Clutch making a clicking noise... HELP!!!!! (eh-D)
is the clutch release bearing hard to replace?
Old 10-01-2002, 09:43 AM
mattL's Avatar
once you have the tranny off no, but what you gotta do to get to it is definatedly a pain. its not necesarily that either, i have a brand new one in mine an it still does it.
Old 02-18-2003, 10:07 PM
Tru Dynamix's Avatar
sorry to bring this up from the dead..but did anyone ever figure out a DEFINITE answer? i JUST bought a used 2000 gsr two days ago and i have the same clicking noise..comes and goes..when i press the clutch in, it has the clicking sounds, when i release, the clicking sounds get louder.. VERY annoying..
ttt for an answer
Old 02-19-2003, 02:41 AM
99integraboy's Avatar
Almost 100% sure it is your throw-out bearing.
Old 02-19-2003, 04:19 AM
Eva01's Avatar
Default Re: Clutch making a clicking noise... HELP!!!!! (99integraboy)
When I had this problem I fixed it putting some grease on the slave cylinder. Instuctions are here in this thread:
https://honda-tech.com/zerothread?id=179021 HTH
Old 03-21-2003, 07:37 AM
ragejed's Avatar
Default Re: Clutch making a clicking noise... HELP!!!!! (Eva01)
Guys, I had my act HDSS clutch for about 6k miles now. I got off the highway today, and when I letoff the clutch fast, even in neutral, i hear a loud clicking noise, metal to metal sound. Deff coming from inside the tranny. Even when I am parked and the engine is off, i hear it. and can feel it in the pedal, ideas?
Old 03-21-2003, 10:17 AM
dip-set's Avatar
any pics as i have no idea where this piece your talking about is so i can do it ...also what other grease is usable....thanks
Old 03-21-2003, 10:25 AM
tilt's Avatar
Just wondering, is the clicking sound different from clutch chatter? I hear that those beefier aftermarket clutches just make more noise natually.
Old 03-21-2003, 12:39 PM
Eva01's Avatar
Default Re: Clutch making a clicking noise... HELP!!!!! (teg-your-it)
Here is a thread w/ some pics to illustrate how to fix this problem. I used the high temp lube that comes in the tubs at Autozone. HTH
Yes this is more of a creaking noise...like something needs to be greased. Clutch chatter is similar to starting in a higher gear at low speeds. Lots of rumbling and shaking from the clutch and in the car.
[Modified by Eva01, 9:43 PM 3/21/2003]
Old 03-21-2003, 12:46 PM
dip-set's Avatar
good **** eva01 ...thanks again for ya help as this wasnt the first time...doubt it will be the last also
Old 03-21-2003, 01:09 PM
Eva01's Avatar
NP Bro! Always glad to help.
LandeZak
09-09-2013 10:38 PM
siboii08
Honda Civic (2006 - 2015)
03-27-2008 08:35 AM
jbsmith
08-29-2005 12:21 AM
Tokyo_X-treme_Racer
18
01-28-2004 11:48 AM
Quick Reply: Clutch making a clicking noise... HELP!!!!!
