replacing hid bulb in a jdm front integra?
Old 03-25-2011, 09:22 PM
2n-chilli's Avatar
Default replacing hid bulb in a jdm front integra?
how do i go about changing my hid bulbs the oem ballast is connected to the headlight where u cant even see the bulb how do i get in there and has anyone else tried to replace oem hid bulbs,and what size r the bulbs for it..thanks any info is greatly appreciated.
Old 03-26-2011, 02:44 AM
pogeeboy27's Avatar
Default Re: replacing hid bulb in a jdm front integra?
There should be 3 (I think) torx bolts to remove. Once those are out, the ballast pops out and you now have access to the bulbs. You will need D2S bulbs.
Old 03-26-2011, 06:19 AM
2n-chilli's Avatar
thanks what does the socket look like where the bulb disconnects from and if some one wired them in can i get aftermarket ones and cut the two wires and wire them in i want a blue color not a white yellow
Old 03-26-2011, 06:23 AM
94rs-turbo's Avatar
the way the housing is you have to use oem setup, and d2s bulb will work
Old 03-26-2011, 08:31 AM
2n-chilli's Avatar
so i can only use bulbs from oem vehicles that require hids??? stock hids r lame i want blue ones not the stock yellow white ones, d2s bulbs from ebay would work ????
Old 03-26-2011, 09:34 AM
Little_Nolan's Avatar
Simple. You need any D2S bulb.. if you are looking for a more blue colored bulb I would suggest a 6000k bulb.
The bulb connector style is a D2S just like tsx/s2k bulbs. Look through the bulbs and info on this site, they are hands down the best for HID components/bulbs and customer services. Try the morimoto 6k's I hear they are quite good.
http://www.theretrofitsource.com/index.php?cPath=27
Old 03-26-2011, 10:02 AM
2n-chilli's Avatar
thank u but cant i just buy d2s replacement bulbs off ebay like the 10 or 12k and clpe them right in i know dont last as long but they r super cheap and look way better is this possible to do???? lmk thanks
Old 03-26-2011, 12:57 PM
They will not last long at all. And they will not look way better, they will perform MUCH worse than a quality bulb and likely worse than a hallogen projector at that point.
Im sorry I contributed to this thread. I thought you were seeking replacement bulbs for your ITR and were looking for better light out-put. Not that blue or pink color, ghey 16yr. old kid, fan boi ricer look.
Old 03-26-2011, 01:36 PM
turbojdmhatch's Avatar
Haven't you seen any of the threads this kid has made?
Old 03-26-2011, 01:44 PM
No I tend to stick to ITRCA... this site just blows sometimes
Old 12-09-2013, 08:31 PM
TRUCHONIC's Avatar
I know that is a old post but my just blow and I don't have that much room cuz of the abs should I have to remove the hole headlight
TurbothisLS
09-30-2016 08:42 AM
Accord1234
Lighting
10
06-07-2008 07:28 AM
NorthernXposure
12-09-2007 08:50 PM
TypeR 599
04-04-2004 01:19 AM
geminis2k
11-04-2003 12:02 PM
Quick Reply: replacing hid bulb in a jdm front integra?
