How to get a smoother ride.
Old 03-15-2011, 12:16 PM
j4s0n1337's Avatar
Default How to get a smoother ride.
I have koni yellow ground control, eibach springs, and top hats on my 95 hatch, it's a major improvement from the stock ****, but what else can I do to it to get the smoothest ride possible? I was thinking about getting a skunk 2 camper kit, but that wouldn't really help with the smoothness. I lowered it 2 inches, I'm not tryna be Mr. Super Slammed, I just want the best ride out of my hatch.
Old 03-15-2011, 12:17 PM
Master Detailer
98civdx's Avatar
Default Re: How to get a smoother ride.
Camber kits wont to **** for ride quality.
Old 03-15-2011, 12:19 PM
Former User's Avatar
Thread copied to the Suspension forum.
Old 03-15-2011, 12:43 PM
tlarimer's Avatar
You dont need a camber kit, if you got money burning a hole in your pocket then I guess you could throw it away on a camber kit.
For ride quality, I am absolutely amazed and happy with the ride, function and price of my OEM ITR springs/struts on my 92 EH3. Lowered the stock height between 1-1.25" and maintained the factory ride. It's definitely not the best suspension out there, but it suits my mods, driving style and taste.
Old 03-15-2011, 12:58 PM
Arthas's Avatar
Get Progess, Gold line, or Tein springs.
Old 03-15-2011, 12:59 PM
Ek Forever y0!
Libertariat's Avatar
Perhaps your bushings are all worn out. A master bushing kit and a solid alignment will make your car precise and smooth.
What spring rates are you running?
Old 03-15-2011, 04:00 PM
the171's Avatar
generally, the more you move towards performance handling, the further away you go from ride quality and comfort. A civic can have very impressive handling for what it is. But the ride is going to suck. Plain and simple. Some say sway bars and other bars help, maybe a little, but its mostly bogus. I say either go all out with stiff springs or stock. nice choice on koni/GC by the way. I love mine, amazing quality.
Old 03-15-2011, 05:09 PM
dy8
dy8's Avatar
extended top hats would help too. i put them on mine with eibachs and kyb agxs, after years of factor mounts, and was surprised it actually rode better.
Old 03-15-2011, 05:23 PM
Ek Forever y0!
Top hats have 0 effect on the way your car rides. Not unless you're accustomed to riding on your bumpstops.
Old 03-15-2011, 06:51 PM
TwoFaced's Avatar
Very good answer.
You'd be suprised at how much bushings will make or break your suspension...
I know it's not suspension but the most apparent display of how effective replacing bushings can be are the shifter bushings. You can go from like 1.5 inches of very free play on either side of your shifter to virtually no free play at all.
Best of luck...
and lulz at ek forever guy's response.
Old 03-15-2011, 06:55 PM
SeanK325's Avatar
How are your tires? Worn tires, or tires of poor quality all factor in ride quality. Anyone can attest to that.
Old 03-15-2011, 07:03 PM
Master Detailer
98civdx's Avatar
on top of that, I don't think you can even use top hats with lowering springs.
Old 03-15-2011, 07:22 PM
InTheZoneAC's Avatar
2" drop with no camber kit? Does your car hydroplane in the rain every time you turn the slightest bit?
usually when you lower the car you're seeking looks and performance, not comfort. What size rims/tires are you running, obviously a thicker sidewall would help.
Old 03-15-2011, 07:35 PM
Never heard of this... Only thing that may be different with a lowered setup might be the bump stops needing to be trimmed, but you definitely use the top hats.
Old 03-15-2011, 07:51 PM
Ek Forever y0!
I don't see why you couldn't.
Old 03-15-2011, 08:42 PM
central09er's Avatar
yea cant really lower a car and expect good ride quality and a thicker tire does help but i swear my 195/50/15s rode better than these 195/60/14s on these steelies im forced to run for the moment
Old 03-15-2011, 09:20 PM
Master Detailer
98civdx's Avatar
Your kidding right? What would his car hydroplane with having a little negative camber?
I was slammed with out a camber kit, and never hydroplaned one time. I live in WA, we get lots of rain.
I am still lowered without a camber kit, lowered 2.5" running -1.8/9*F and -1.9/2* in rear. Never had the slightest issue.
It's been said many times in the suspension forum by many knowledgeable people.
I think it was something with pre load, and another thing.
I always thought you could, but they say other wise.
AaronGeisinger
05-19-2008 07:29 AM
iheartmyEG
09-05-2006 06:53 PM
Ratchback
16
09-19-2004 08:01 PM
Loveless
09-28-2003 01:01 AM
stoopid215
09-12-2002 09:40 PM
Quick Reply: How to get a smoother ride.
