Honda Ruckus and Scooters Ruckus, Silverwing, Reflex, Helix, Metropolitan
Help: my ruckus will not start
Old 03-01-2011, 07:38 AM
LunDC's Avatar
Default Help: my ruckus will not start
So I've recently purchased an '06 ruckus with 11,xxx miles on it. At first I could kick start it and it would run perfectly fine. Now it won't do anything. I've replace the battery and a couple of miner things and still nothing. Anybody have any ideas?
Old 03-07-2011, 02:01 AM
Ruckus2009's Avatar
Default Re: Help: my ruckus will not start
Is it stock or did you do somethin to the scooter?
Old 03-08-2011, 05:06 PM
kcjohnnyboy's Avatar
are you holding either one of the brake handles then starting it up with the button at the same time?
Old 03-09-2011, 09:55 AM
LunDC's Avatar
The guys at totalruckus.com helped me out. It's running now. Thx
Old 03-12-2011, 05:42 PM
what did the problem end up being?
Old 03-13-2011, 10:59 AM
yoshi_1r671's Avatar
thought id chime in cuz i need help..im a nooob.... i have the same problem right now.. i just got my 06 ruckus....it has a new battery...rode it yesterday for about 15 minutes around the block...turned it off for 20 minutes..then tried riding it again but no start...push start was just clicking... all lights worked except the headlights(since it wasnt running).. so i did kickstart and it ran for 20 secs then died... you guys got any ideas??? kick start wont work either.....
5 minutes later...
so i tried kickstarting it again, and its running right now... i guess its a bad battery too...its walmart ever start battery that the last owner put...
5 mins after that.. saw this.. the positive cable for the battery was loose..does it connect to that small blue box??
any help?? ive tried to attach the positive wire back but still no on the push start button..and the kick start gets it running for like a few seconds
now i have a clicking noise then the key is on the ON position?? wtf
Old 03-14-2011, 04:46 PM
LunDC's Avatar
It was in desperate need of a tune up. New plugs, oil change, and a couple of minor loose connections. I got it from a pawn shop and the previous owner didn't take good care of it
kevinhughes13
10-06-2014 12:28 AM
tran1088
Acura TSX
01-19-2012 11:51 AM
ylor4
11-14-2008 09:02 PM
gsf4726
11-26-2003 04:10 AM
Quick Reply: Help: my ruckus will not start
