SHARE YOUR STANCE - The guide to achieving that ideal setup...
Old 03-10-2014, 11:08 AM
  #976
PINKFIFFTY's Avatar
Default Re: SHARE YOUR STANCE - The guide to achieving that ideal setup...
Jshadsi, I dont know about a 225 with that wheels size and offset but I know you can pull off 225s on an ej/em1 my buddy runs a 15x7+41 with a 225 only has fenders rolled and only rubs slightly on the inside on tight turns, but with that offset your talking a out your probably going to have to run something smaller like a 195 or 205 if you don't mind rolling your fenders should work but rolling had its drawbacks, would also reccomend better tires than those khumos if you want to get that power to the ground, have heard they arn't that great, azenis are one great option;-) I dd mine and love em too death
Also I would recommend putting the wider wheel in the rear it will look better and haveing the wider wheel won't give you any performance benefit if your ruining the same tire size
Old 03-10-2014, 11:48 AM
  #977
hmoobvwj's Avatar
PINKFIFFTY - Hmoobvwj, read through this thread
https://honda-tech.com/forums/showth...238&styleid=18
I think typically they recommend about 500lb front 350lb rear if you want to be pretty low, some say a little stiffer but I don't think you can go over 600lb without revalving the konis, you also can go a little softer but you don't want to go too soft if slamming and have issues with bottoming out
Yeah I've trying to gain as much information and private message everyone I see with the same set up. I am probably going to go 550F/450 OR 500R OR 500F/500,450,400R. I am still trying to decided.
Old 03-10-2014, 12:34 PM
  #978
jshadsi315's Avatar
Ya I plan on rolling and pulling the fenders as much as possible I have an eastwood roller i used to roll the fenders on my Evo 8.
I think I'm going to go with a 215/45 Falken azenis on all four corners, It just sucks that there is only a couple options for tires in that size.
The car isnt going to be lowered to much, I'm not going for stance I want the car to be functional and corner hard!
Ive though about doing 205/45/16 with some Toyo R1R's but I'm dont know. I cant find anyone thats running a meaty aggressive setup like this on an em1 without -3 degrees of camber or more. Everyone runs a streched slammed setup...
Id like to run 225/45 up front cause I have a great tire selection, but I'm worried that a 16x8.5 +24 is going to poke with tires that size, I already know I'm going to prolly have to run about -2.5 for camber which is fine
Old 03-10-2014, 03:43 PM
  #979
PINKFIFFTY's Avatar
hmoobvwj, 500lb in the rear is really stiff would definitely be uncomfortable for cruizing around town maybe a track car that you occadionaly drive but definitely not something you drive all the time, definitely read through that thread I posted has a lot of good info about choosing good spring rates
Old 03-10-2014, 06:55 PM
  #980
PINKFIFFTY's Avatar
Jshadsi, since you are planning on pulling your fenders that definitely makes things easier. I agree that the Azenis or Toyo r1r sound like a great tire choice. The main issue with the tires fitting is the offset if you had 16x8+30 or +40 it wouldnt be such an issue. You can do the fended roll+pull before ordering tires and test fit the wheel and see how everything lines up and if you think the 215s will clear order 2 have them put on and find out a definite and if it doesnt quite fit you can give your fenders a little extra pull or you can take tires back off and put them on the 8.5" in the rear and order some 205s for the front or if all goes well order 2 more 215s for the rear. What are your plans for the car are you gonna be doing alot of tracking or just haveing something fun to drive and looking good doing it?
Old 03-10-2014, 08:04 PM
  #981
jshadsi315's Avatar
The car is mainly my daily driver but I will be using it for autox, and going to the track from time to time. Right now the car is riding on Blistein struts with tein springs but i plan to get sk2 sleeves but i wont be going much lower I would like the tires to be just even with the fenders (no tuck)
Old 03-11-2014, 04:41 PM
  #982
Twin Cam's Avatar
Wheels: BBR Competition
Specs (i.e. size, width, offsets): 14x6.5 +32
Tire specs: 195/60-14 Falken Azenis RT-615K
Suspension setup: Skunk2 coilovers (500f, 600r) with Koni Yellows
Camber specs: (-2) front (-1) rear
Jack Point Measurement (from ground): Not sure
Additional comments about your setup: This suspension has been good for anything. Do a lot of street driving, a little auto-x, and some drag racing.
Overall rating of your setup (1-10): 8
Old 03-13-2014, 07:58 AM
  #983
strigga's Avatar
Love this thread!
exactly what i was looking for! Please post more pics and specs!
Old 03-17-2014, 04:29 PM
  #984
82BUCKET's Avatar
No wagon's??.....I think I'm getting 16x8...+25 and 195/55 ....anybody running this set up?...on a small drop... 1-2"....?
Old 03-27-2014, 06:53 PM
  #985
Battle Monkey's Avatar
Wheels: Braid Fullrace A Maxlight
Specs (i.e. size, width, offsets): 15x8 +38
Tire specs: 225/45-15 Hankook Ventus Z214
Suspension setup: Koni Yellow w/ Ground Control kit 400lb/500lb (f/r), 22mm fsb, 26mm rsb
Camber specs: (-2.8) Front (-2.1) Rear
Ride Height: 12.5" from hub center, all around
Additional comments about your setup: No rubbing on initial test, track test to come this weekend. Once I get some stiffer springs I will probably lower the car another .5" or so. More to come after the weekend!
Old 03-29-2014, 05:28 PM
  #986
furious94ls's Avatar
2003 Honda Accord EX-L V6 6MT 132k. Daily driver (except for winters)
Wheels: OEM optional Acura TSX A-SPEC
Specs : 17x7.5 55
Tire specs: Dunlop Direnza (summer tires)
Suspension setup: H&R Sport on Koni yellow adjustables (lower perch front, middle perch rear) set at mid stiffness all around
Camber specs: stock
Additional comments about your setup: Rides firm, yet comfortable. Love it.
Old 04-16-2014, 10:47 AM
  #987
bigbpatel's Avatar
New rim setup:
Wheels: JLine SDM RL 2
Specs (i.e. size, width, offsets): 17x10 +25
Tire specs: 225/45-17 Michilin A/S Plus
Suspension setup: Accuair E-level with AirLift struts/bags
Ride Height: 3 preset settings, slammed, low driving and high driving
Additional comments about your setup: Dual Vial 444C Compressors, dual silencers, 2.5g tank, few other upgrades
Overall rating of your setup (1-10): 9
Size:  2.19 MBName:  IMG_4457_zps2247f50c.jpg
Size:  2.20 MBName:  IMG_4429_zpsdb0ecc19.jpg
Old rim setup
Wheels: Rota D2
Specs (i.e. size, width, offsets): 17x8.5 +25
Overall rating of your setup (1-10): 6
Old 05-06-2014, 11:31 AM
  #988
Ed7touge's Avatar
Wheels:
Specs (i.e. size, width, offsets): 15x9.5 -5 front, -12 rear
Tire specs: 195/45 Toyo Proxes
Suspension setup:
Ride Height:
Additional comments about your setup: Not everyone's ideal setup, but on this on I decided to go very aggressive.
Last edited by toyomatt84; 05-06-2014 at 04:27 PM. Reason: Look at the first post, and use the correct format here.
Old 05-06-2014, 12:02 PM
  #989
Caddiman's Avatar
Wheels: Rota Grid V
Specs (i.e. size, width, offsets): 16x8 ET20
Tire specs: 195/45/16 knockoff tires
Suspension setup: Ground Control with Tokico Illumina struts
Camber specs: Stock Camber
Jack Point Measurement (from ground): Unkown
Additional comments about your setup: Ride is good for being as low as it is. I can go about an inch lower then I would be maxed out. I like the fact that I can adjust my shocks.
Old 05-13-2014, 04:19 AM
  #990
acurarolling's Avatar
Wheels: Weds Kranze Bazreia
Specs: 19x10 +5 front, 19x11 +12 rear
Tire specs: 225/35/19 and 245/35/19 nankang S2
Suspension setup: Megan ez street coilovers
Camber specs: this is a guess front -3.4 and rear -8.2
Jack Point Measurement (from ground): 3 inches
Additional comments about your setup: fenders rolled and pulled (13mm in the front, less than 5mm in the rear)
Overall rating of your setup (1-10): 7
Last edited by acurarolling; 07-09-2014 at 03:46 PM. Reason: added correct camber numbers
Old 05-14-2014, 08:47 AM
  #991
maineef's Avatar
Wheels: STR 606
Specs : 15x8 +20
Tire specs: federal super steel 185/55r15
Suspension setup: g/c sleeves on koni
camber adjustement: rolled fenders
3 degrees in the rear
2 in front
Additional comments about your setup: lil bumpy switching to one piece soon
Old 05-15-2014, 07:11 PM
  #992
torontoefsedan's Avatar
Wheels: ESM
Specs: 16x8 et15 front, 16x9 et20 rear
Tire specs: 195/40/16 Federal
Suspension setup: Skunk 2 Pro
Camber specs: Natural camber, stock camber arms.
Jack Point Measurement (from ground): No idea.
Additional comments about your setup: Fenders rolled, fronts not even flattened, rears relatively flat, minor pull as a result
Overall rating of your setup (1-10): 69
Honda by christopher.johnston, on Flickr
Old 07-04-2014, 12:32 AM
  #993
Occulus's Avatar
My old set up:
Wheels: Volvo steelies widened 4x114.3
Specs: 15x8.0 f and 15x8.5 r
Tire specs: Kuho ecstas 195/50/15
Suspension setup: BC br racing
Camber specs: Six Performance front and rear
Jack Point Measurement (from ground): Don't know but I had to cut the front mud flaps in half.
Additional comments about your setup: Fenders rolled and max pulled front and rear.
Overall rating of your setup (1-10): 7.5
Current set up on 17" Drag dr something...
Old 07-09-2014, 12:45 PM
  #994
just Touge's Avatar
What does that even mean? Do you mean factory camber settings?
Old 07-09-2014, 05:20 PM
  #995
autox228's Avatar
Wheels: Work VS-XX
Specs (i.e. size, width, offsets): 18x9 ET25
Tire specs: 215/40/18 Nitto NeoGens
Suspension setup: Buddy Club N+ Coilovers
Camber specs: Natural f/-1.8 and Ingalls rear camber kit r/-2.9
Additional comments about your setup: I have to camber more of the rear, currently rubbing on passenger rear coilovers. I could run a little softer in the rear dampening to make it a smoother ride.
DSC_6555 by jeffNGUYENer, on Flickr
Old 09-10-2014, 09:35 AM
  #996
caleb.thomasd's Avatar
Should 15x8 +15 wheels fit my ej8 with 225/60R15 tires?.. Or would a 195/55 fit better? Also, what exactly does HPO mean? Some wheels I'm looking at say 15x8, offset: HPO, but then in another spot it says "These wheels come in a 15x8 +25 ET for the hellaflush look".... So my last question... What is ET? Sorry I know like nothing about wheel specs.... I just dont wanna blow 1000 bucks and the wheels not even fit...
Old 09-10-2014, 06:42 PM
  #997
steveff's Avatar
Wheels: Konig Wideopen
Specs (i.e. size, width, offsets): 15x8 et20
Tire specs: 165/55 Federal Evo595
Suspension setup: Koni SP3 / Ground Control Koni Sleeves / Stance 2.5 ID coilover springs 12k front 8k rear. 2" extended top hats front and rear. Cut shock towers. Prothane Poly bushings everywhere.
Camber specs: Natural- front 4.8 rear- 3.6
Jack Point Measurement (from ground): 1.5 inches
Additional comments about your setup: Upper control arm has no more travel. Need to fab up some drop spindles to fix this issue. Going with some drop forks as well for more shock travel. Moving to 16k front and 12k rear springs after the winter. Needs to be stiffer at this height.
Overall rating of your setup (1-10): 8. Needs more stiff. Needs more low. Needs more wide. Going 15x10 et-25 after winter These are the only decent pictures I have right now.
Old 10-20-2014, 08:23 PM
  #998
jdmwatch's Avatar
Wheels: traklite octane hyperblack
Specs*: 15x8 +15
Tire specs: federal super steel 175/55r15
Suspension setup: unknown coil sleeves on stock shocks
camber adjustement: rolled fenders*
??????in the rear tomorrow I'll be making the measurements
?????? in front. " "
Jack Point Measurement*(from ground):*" "
Overall rating of your setup (1-10): 5
Old 11-01-2014, 03:32 PM
  #999
badassmthr4000's Avatar
This is a fancy way of saying "I'm running factory control arms"
On my DB2, my "natural" camber after alignment at my ride height was approx -5 on all four corners. Rode on that set up for over a year with no abnormal tire wear whatsoever. Switched up wheels and tires recently, and I'll be going back in for another shortly.
Old 11-03-2014, 10:27 PM
  #1000
hmoobvwj's Avatar
Wheels: xxr 531
Specs*: 15x8 +0
Tire specs: federals 165/50/R15
Suspension setup: koni yellow with ground control, ground control top hats
camber adjustment: N/A
Jack Point Measurement*(from ground): Not sure (probably 1.5"-2")
Additional comments about your setup: Rolled fenders' lip flat
Overall rating of your setup (1-10): 8.5
Quick Reply: SHARE YOUR STANCE - The guide to achieving that ideal setup...
