1994 acura integra wont start
Old 02-02-2011, 06:05 PM
nicholasdarnell's Avatar
Icon2 1994 acura integra wont start
I have a 1994 acura integra and it cranks but no spark..... have replaced the main relay and the distributor..... need help.... im gonna try to turn the distributor 180 to see if it help but need more suggestions
Old 02-03-2011, 09:23 AM
redline1219's Avatar
Default Re: 1994 acura integra wont start
Well first off, if you know you dont have spark then replacing the main relay is pointless (being the fuel pump relay). I you replaced the distributor already, where did you get it from? I do not suggest aftermarket, they will fail in no time... Check if the ignitor is doing its job by putting a test light on the neg and pos terminals of the coil and crank it over. If the test light flashes, then the ignitor is sending the coil a signal but the coil is not working. If there is no flashing on the test light, then the ignitor is not working and cant tell the coil to fire spark. Its not easy to put the distributor in backwards (not to say its not possible, but you would know if you did) so what else is left, see if the timing belt is broken (which wouldnt spin the distributor, no spark) and also check to see if your plugs are on the distributor in the correct order.
Hope this helps...
-Phil
Old 02-04-2011, 12:02 PM
Ya i took a electrical tester and turned the key on and checked the coil and it gave me 12.6 volts out of the coil so i'm thinking it is the cap or maybe the rotor?
Old 02-04-2011, 12:17 PM
kyden's Avatar
does your distributor turn?
Old 02-04-2011, 02:15 PM
yes it turn
Travis Davidson
07-25-2017 07:11 PM
ef yu
03-20-2012 11:58 PM
ecerva5792
07-22-2010 06:20 AM
civicboisi
11-29-2009 06:09 PM
jonnybadboi9
03-14-2007 06:17 PM
Quick Reply: 1994 acura integra wont start
