My car keeps stalling coming to a stop
Old 02-03-2011, 04:42 AM
  #76
Bowl_of_Rice's Avatar
Default Re: My car keeps stalling coming to a stop
ill check again today i didnt really spray it, i did a light spray
Old 02-03-2011, 05:16 AM
  #77
N/A
Purpose Built
N/A's Avatar
If you are using brake clean it dissolves quickly so don't go crazy but don't be afriad to give it a good spray.
And the idle screw is just like anything else left open right closed
Old 02-03-2011, 07:52 AM
  #78
alright cool ill try that out soon
Old 02-04-2011, 03:53 AM
  #79
i think i do have a vacuum leak somewhere just cant find it, the car idles fine but when i drop the car into neutral itll idle at 1100 then drop back down to 750 800 when i completely stop it wont drop back down until i completely stop the idle sometimes i mean SOMETIMES drop like it used to but not as bad. also the car doesnt stall in the cold anymore whew making progress lol
Old 02-04-2011, 05:56 AM
  #80
fcluddington's Avatar
At least you can now drive it without it stalling out. Stop spaying brake fluid wait until you get a known good TB on their. btw your idle is going to change you need to read up on what all makes it change. like ELD, the AC, engine coolant temp. etc. 1100 sounds perfect at start that would be fast idle. once the car is warm it drops down to 800rpm sounds good.
Old 02-04-2011, 06:03 AM
  #81
N/A
Purpose Built
N/A's Avatar
What accessorys are on the car?
Old 02-04-2011, 07:50 AM
  #82
i dont have ac so that cant change anything lol, i dont really have any accessorys if you mean like a radio a sub and stuff, well someone broke into my car and stole my radio my gps and my ipod and the change out of my coin holder lol, so all i really have is a car charger
Old 02-04-2011, 03:31 PM
  #83
happyc4mp3r's Avatar
could it be the brake booster?
Old 02-04-2011, 04:07 PM
  #84
N/A
Purpose Built
N/A's Avatar
Your a real piece of ****in work
Old 02-04-2011, 05:32 PM
  #85
haha
got a compression test
Cylinder 1- 200
Cylinder 2- 205
Cylinder 3- 185
Cylinder 4- 175
added oil into 3 and 4 cylinder 3 went up 10 and cylinder 4 went up 15
does that mean bad piston rings? can that mean a bad valve too?
Old 02-04-2011, 06:07 PM
  #86
MD426's Avatar
Likely the rings but those numbers arent too bad, non vtec right?
Old 02-04-2011, 06:15 PM
  #87
dpetro1's Avatar
how did we go from idle problem to piston ring failure?
Old 02-05-2011, 06:41 AM
  #88
because i dont like making multiple threads when i already have one active one
and yes its a non vtec
Old 02-05-2011, 07:03 AM
  #89
N/A
Purpose Built
N/A's Avatar
Rings
Old 02-05-2011, 07:29 AM
  #90
94VTEC2TONE's Avatar
have you put a scanner on this thing at all see what kind of pid values u get?
Old 02-06-2011, 06:51 AM
  #91
If the issue is resolved about engine stopping when coming to a stop. You could help others by starting a different thread title. because who would look in this thread about troubleshooting compression test numbers.
Old 02-06-2011, 06:56 AM
  #92
el crapitan's Avatar
you may not have an actual vacuum leak. it could be a collapsing/collapsed line. in which case spraying starter fluid won't show you anything. that's why the gauge is the best way to test. have you tried it yet?
_Tim
10-11-2008 12:00 PM
inside0ut
08-30-2008 08:52 AM
mark2583
01-09-2008 03:13 PM
Boofster
05-22-2005 10:59 AM
warrenbaity
04-16-2004 11:43 AM
Quick Reply: My car keeps stalling coming to a stop
