Car pops out of 5th gear
Old 09-18-2010, 12:41 PM
kevinm1981's Avatar
Default Car pops out of 5th gear
My car pops out of 5th gear? Why could this be? Could a hole in my exhaust vibrate and make it pop out?
kevinm1981 is offline
Old 09-18-2010, 01:13 PM
DanielSLe's Avatar
Default Re: Car pops out of 5th gear
Maybe its time for a new tranny.
DanielSLe is offline
Old 09-18-2010, 01:15 PM
madjap's Avatar
^^^This^^^
madjap is offline
Old 09-18-2010, 02:04 PM
kevinm1981's Avatar
Seriously?
Old 09-18-2010, 02:40 PM
hatchet_honda's Avatar
synchros!! does it come out of gear once you release the gas pedal?
hatchet_honda is offline
Old 09-18-2010, 03:15 PM
PyroProblem's Avatar
Ive seen low fluid levels cause this exact same thing. Check the fluid level first.
PyroProblem is offline
Old 09-18-2010, 03:28 PM
kevinm1981's Avatar
the clutch fluid has been depleting slowly, but there is plenty in there.
Old 09-18-2010, 03:29 PM
kevinm1981's Avatar
haven't tried that... it usually pops out when going 50 or faster. the faster i drive the quicker it pops out.
Old 09-18-2010, 03:32 PM
lobudgetr's Avatar
The fluid he was refering to was gear oil. I had a trans that leaked itself dry on a long drive once and it started popping out of 5th if I wasn't holding the shifter. Put oil in the trans and it was fine after that. Could also be a bad synchro.
lobudgetr is offline
Old 09-18-2010, 03:37 PM
kevinm1981's Avatar
ok thanks...
Old 09-18-2010, 03:38 PM
EJeff8's Avatar
change your MANUAL TRANSMISSION FLUID. It should help. If it doesn't, it's your 5th gear synchro.
EJeff8 is offline
Old 09-18-2010, 03:42 PM
300whpej's Avatar
drain your tranny fluid, fill up with honda MTF and see if it comes back. ~20 worth of fluid is a lot cheaper than a 300+ trans.
300whpej is offline
Old 09-18-2010, 03:47 PM
kevinm1981's Avatar
ok, will do that..
Old 09-19-2010, 11:16 AM
kevinm1981's Avatar
Ok, did some tests, it only does it when on the gas pedal and only 5th gear...
changing out the tranny fluid for honda mtf tomorrow.
Old 09-19-2010, 11:58 AM
D Griff's Avatar
SOunds like a good, easy first step.
D Griff is offline
Old 09-19-2010, 12:40 PM
yeaaa...im thinkin your trans is goin..
Old 09-19-2010, 03:35 PM
gchurchie's Avatar
it's telling you it wishes there was a sixth.
gchurchie is offline
Old 09-19-2010, 03:39 PM
tuck1crx's Avatar
i wouldnt drive it at all until u change the fluid. if it just low u risk f***in ur 5th synchro
tuck1crx is offline
Old 09-19-2010, 03:41 PM
92lxsleeper's Avatar
well just be glad that trannys' for the ex only cost about $150 at the junkyard.
if you wanna be cheap you can get a DX trannyy for about $70 at the junkyard, and just suffer a little acceleration loss, and the gain of better fuel mileage. and you can take it out, put a clutch in, and put the new tranny in, in under 4 hours
92lxsleeper is offline
Old 09-19-2010, 03:44 PM
kevinm1981's Avatar
motor is a jdm b18c
Old 09-19-2010, 03:49 PM
Originally Posted by kevinm1981
motor is a jdm b18c
well it will be cheaper to open it up and replace the synchros than to replace the tranny.
Old 09-19-2010, 05:17 PM
300whpej's Avatar
have you changed the fluid? if not do it and report back.
300whpej is offline
Old 09-19-2010, 05:19 PM
REDEM1FTW's Avatar
I had this EXACT SAME PROBLEM in my hatch and it was low tranny fluid, change your fluid i can almost guarentee thats the problem. Post back and let us know what happens.
-Josh
REDEM1FTW is offline
Old 09-19-2010, 05:29 PM
kevinm1981's Avatar
good to hear that... i will let you guys know.
Old 09-19-2010, 06:12 PM
blackchoad's Avatar
low tranny oil ... ill say... eventually your gonna start grinding
blackchoad is offline
Quick Reply: Car pops out of 5th gear
