OBD2B -> OBD1 IACV
Old 08-13-2010, 06:51 AM
Momentum's Avatar
Default OBD2B -> OBD1 IACV
Im running OBD1 ECU -> Jumper Harness -> OBD2B Wiring Harness and OBD1 motor.
How come my Jumper Harness doesn't have this already re-wired? My jumper does not have a wire coming out of B6 but it does have a wire coming out of B23.
Im trying to research how to rewire the IACV from my harnesses 3-wire to the OBD1 2-wire but all I keep finding is this one picture.
Is this the proper diagram for what i'm doing? If this is the proper one, I will remove the orange wire and move the black wire from B6 to B23. But then what do I do on the IACV plug end? Do i cut off my OBD2 plug and sodder the OBD1 plug in?
Which wire do I splice to which? I dont think the 2 wires from the OBD1 plug and the 2 wires from the OBD2 plug match (once you remove the orange wire)
Thanks!
Old 08-13-2010, 07:11 AM
Momentum's Avatar
Default Re: OBD2B -> OBD1 IACV
Nevermind I found this. I believe this tells me everyting i needto know.
dar5052
12-19-2011 09:29 AM
my1992cb7accord
12-15-2011 09:47 PM
pipojdm
09-13-2008 01:09 AM
SpoonyGSR
18
08-18-2005 05:16 PM
5 Skware
07-30-2003 04:38 AM
Quick Reply: OBD2B -> OBD1 IACV
