ALTERNATOR & BATTERY PROBLEMS - B16 swapped eg hatch! Help!
Old 08-06-2010, 06:02 PM
REDEM1FTW's Avatar
Icon3 ALTERNATOR & BATTERY PROBLEMS - B16 swapped eg hatch! Help!
i have a 93 civic cx hatch with a jdm b16 swap and am about to loose my sanity over alternator/battery problems. sorry for the novel in advance.
THE PROBLEM: I was driving my car two days ago and all of a sudden my radio starts turning on and off, then my rpm and speedometer gauges quit working and then my headlights got really dim. about 5 minutes after this happened,my car just completely puttered off and died. I tried to crank it up again but my battery was completely dead so i took it to autzone to get it charged and checked out. when i went and picked it up they told me that the battery was fine and fully charged. i popped the battery in and was on my way figuring that that was the problem.
WRONG. Same thing happened to me the next day except this time when i turned my car on the battery light came on and stayed on till i revved it up a little bit and then it went away. i turned it on and off three times to make sure it wasnt a one-time thing; it happened each time.
Next step was to change the alternator. i swapped alternators and everything seemed gravy till i turned it off and then on again and then the damn battery light just stayed on the whole time?? i also pulled out all the fuses to see if the alternator fuse was blown and they were all good so now im stuck and dont know wtf to do next.
IF ANYONE HAS HAD A SIMILAR PROBLEM OR ANY ADVICE IT WOULD BE GREATLY APPRECIATED BC IDK WHAT TO DO NEXT.
thanks in advance,
Josh
Old 08-06-2010, 06:06 PM
Former User's Avatar
Default Re: ALTERNATOR & BATTERY PROBLEMS - B16 swapped eg hatch! Help!
Make sure the alternator plug is firmly seated and that the belt and mounting bolts are tight. If those are fine, the "new" alternator may be bad.
Old 08-06-2010, 06:39 PM
REDEM1FTW's Avatar
Plug, belt and bolts - check.
I'm thinking about just buying a new one from autozone and seeing if that fixes it and if it doesn't then I'll just take it back lol
btw, thanks for the suggestion Ron any other suggestions would be appreciated!
- Josh
Old 08-06-2010, 08:16 PM
REDEM1FTW's Avatar
bump
Old 08-07-2010, 05:01 AM
Resident Gearhead
BryanM.'s Avatar
Have AutoZone test the "new" alternator before replacing it.
Old 08-07-2010, 04:09 PM
REDEM1FTW's Avatar
Still not fixed but I have one question, what is the actual thing that makes the battery light come on? A dead battery, battery not charging?, etc...?
Old 08-07-2010, 04:57 PM
Originally Posted by REDEM1FTW
...I have one question, what is the actual thing that makes the battery light come on?
A bad alternator -- The charging system light (battery symbol) turns on when the voltage output of the alternator drops below battery voltage.
Old 08-07-2010, 06:48 PM
REDEM1FTW's Avatar
Icon3 Re: ALTERNATOR & BATTERY PROBLEMS - B16 swapped eg hatch! Help!
I just got my "new" alternator checked out at Orielys and it's only putting out 11.96v and I got the old one tested on their machine and it passed. I'm thinking of trying to put the old one on again and see what happens since everything (battery/alternator) Is testing "good". If it persist I'm pretty sure that it is going to be a wiring problem...
Old 08-07-2010, 07:01 PM
93b20z's Avatar
If everything checks out, do a volt drop on your wires...
Old 08-07-2010, 07:30 PM
REDEM1FTW's Avatar
Are you sure they didn't switch the new and old alternator? That would make more sense to me.
I tested the "old one" at autozone on the car an they said it failed,changed alternators and tested the "new one" while it was on the car at orielys and it failed. Then the old one was off the car and I got it tested AGAIN just to make sure it was bad like autozone said but it passed at orielys. I'm confused.
Old 08-07-2010, 07:56 PM
I misread your post. It sounds like the new alternator is definitely bad, explaining the charging light coming on. Go ahead and reinstall the old alternator to see whether it works.
Old 08-09-2010, 09:40 AM
REDEM1FTW's Avatar
Installed old alternator and everything seems ok now for the time being. It's funny how hondas have minds of their own haha
thanks for all the replies,
- Josh
Old 10-15-2010, 10:45 PM
dd13lbsgsr's Avatar
- Josh
I am having that same problem did you do any thing to fix it because I have change my alternator 3 times and its doin the same thing your was doing
Old 10-16-2010, 08:49 AM
chatch82's Avatar
check all the chasis grounds.......this fixed my problem!!! as weird as it sounds!!
Old 10-17-2010, 11:51 AM
dd13lbsgsr's Avatar
Ill do that thanks
Old 10-25-2010, 06:09 AM
99sijunkie's Avatar
Now I am having the same damn problem! I have a jdm B16A swap in my EK and my battery keeps dying; even after, a new alternator, a million charged batteries and a couple of new ones. I must say, after all this, I do not trust auto zone batteries and their dinky little tests. Anyways, I finally had some fuses replaced and that has seemed to work for the past few days but my car is starting to get a weak start...AGAIN. I am praying it's not a bigger, more frustrating wiring issue at hand but I am afraid it might be. We will see.
Old 01-21-2011, 12:35 AM
dc_man99's Avatar
maybe come one on this post can help me im guessin its my alternater is goin out here is whats happening
cluster just dropped and no lights
climate control
cd player got really scratchy then music would play then turned off
and my hids and fogs went out
all seem like alternater but i dont want to take it out if thats not the problem of if any one else can help me
message me if you think you might know and thanks for the help
Old 01-21-2011, 03:08 AM
The Grumpiest
grumblemarc's Avatar
No one's gonna message you. Get your alternator tested.
Old 11-03-2011, 10:04 PM
EGjdm702's Avatar
im having the same problem if u have fixed your problem let me know please.....
Old 04-05-2013, 01:47 PM
v!taminb16's Avatar
Bumping a old thread but did you ever figure out the problem? I got a new battery, alternator checked grounds even put a new ecu in, the alternator belt spins on perfectly fine alternator
Old 04-05-2013, 02:26 PM
jbpnoman's Avatar
Lets see here, one person solved the problem by replacing their alternator, another by replacing fuses, another by checking their engine grounds...would you like us to read the thread to you?
Old 04-06-2013, 07:06 AM
v!taminb16's Avatar
Yes then I want to add you on xbox and whoop your *** in the game of your choice
Old 04-06-2013, 11:03 PM
jbpnoman's Avatar
An internet warrior who even wants to stay on the internet. Keep it classy, kid.
Old 04-22-2013, 04:47 PM
EGjdm702's Avatar
very late im sorry lol...but this was the issue with my eg was that the main power cable from the alternator got melted and keeped on getting shored out becuase it was hitting the firewall some weird way best think i can say is check your full engine harness and all the connections to the fuse box...my problum was the extended battery cables to the fuse box and from the fuse box to the auto cross terminals was a false connection so keep in mind this keeped on blowing my fusee...it took me for ever to figure it out but i got it fixed mostlikly check ur engine harness make sure no cables where but and connected wrong or got dissconected from hard driveing hope this help...sorry for so long of a responce
Johnoolo
09-16-2013 05:15 AM
Touek
10-21-2011 03:20 AM
jDm bEeZy
03-20-2011 07:32 AM
gsrpedro
14
02-05-2008 01:14 PM
Quick Reply: ALTERNATOR & BATTERY PROBLEMS - B16 swapped eg hatch! Help!
