No Brake Lights
Old 06-18-2010, 09:03 PM
96Formula6spd's Avatar
Default No Brake Lights
Hey guys my brake lights are not working on my crx. I have checked the switch and its working. Replaced with a working one and no change. However the taillights work with the lights on no problem. However when I hit the brakes the door ajar light comes on. The front body harness is new and the back is the original. It does not look cut. I have the rest I just need to install it. I have a feeling they were not working before I swapped the front body harness. Any ideas or things to check? Trying to get this fixed before I get pulled or worse an accident.
Old 06-18-2010, 09:07 PM
EFficial's Avatar
Default Re: No Brake Lights
check the plug above the brake pedal and pull your rear lights for and loose/open wires
Old 06-18-2010, 09:08 PM
plug is in. Lights were checked and everything looks good.
Old 06-18-2010, 09:33 PM
littlewagon's Avatar
Did you check the fuse?
Old 06-19-2010, 10:57 AM
yep fuse is good unless its separate from the taillight one/cluster one
Old 06-19-2010, 11:04 AM
black0hatch's Avatar
if the fuse is good and everything is plugged in. it could either be the switch itself or the wireing.
Old 06-19-2010, 11:05 AM
yeah its down to wiring. Switch got replaced and no change. They worked when I bought then a week later they did not. Going to rewire the car from the dash to the back and forget about it.
Old 10-16-2010, 03:57 PM
Rease3's Avatar
update on fix?
Old 10-16-2010, 08:02 PM
Originally Posted by Rease3
update on fix?
Ended up running a new power wire to the switch. Works great now. 10 min job over a couple of hours for the whole harness change.
Old 10-17-2010, 09:08 AM
tunerEF9's Avatar
this did the same thing in my 91 hatch i just ran a new wire also, curious though why this is happening kinda strang maybe its just an ef thing lol...
Old 03-19-2012, 09:21 AM
BiG ChOr!Zo's Avatar
do you got a diy on how you did this. my brake light fuse keeps blowing out and only the regular lights stay on in the rear. im figuring there is a short somewhere but rather than tear out the engire wiring this seems like a ok fix for now.
Old 04-12-2012, 08:42 PM
91STDFLOW's Avatar
Same here, my hatch just had all three brake lights stop working, fuse is fine, brake grommet is new, bulbs look good, only thing I can think is ground in wire somewhere.
White and green wire is power correct? Any hint on size?
EF Durty MX
11-08-2006 05:57 AM
hellogsr
07-09-2006 08:52 PM
joop411
02-04-2004 09:33 PM
-Whitey-
02-24-2003 01:16 PM
EGh22aEG
08-25-2002 01:28 PM
Quick Reply: No Brake Lights
