shift linkage problem?
Old 06-12-2010, 05:58 AM
'95 BA8's Avatar
Default shift linkage problem?
Hi all, well I thought I had scored a good deal on this car, but I guess not if it's giving me problems a week and a half into ownership right?
Anyways my problem is:
I can't shift into first or third.
Description:
If I'm at a light for example and I try to move the shifter to the first position the shifter goes ALL the way to where first would be, but it's as if there was nothing there, there is no grind, no stop, just feels as if neutral would extend in there, if I then do the same hand movement as if to move to first it eventually catches(you know what you feel when the car is actually going in a gear,) then I can shift to second fine, but if I go to shift to third it's the same thing, if I was to keep my hand on the shifter and held in the 3rd position the car will just rev up, gears aren't grinding, they aren't making any noise, if I let go of the shifter it springs back into neutral, so it's not popping out the gear because it isn't even going in gear!!
2nd, 4th, 5th and reverse work fine and ALL the time.
It almost feels as if the linkage was getting stuck somewhere in the process, or maybe as if the cable wasn't moving all the way, because since the gear isn't catching, I feel like it's just not reaching the point it has to so the car can be in that gear.
The clutch fluid is fine, the pedal feels fine, I'll check my transmission oil level in a few hours but that should be fine to, and additionally wouldn't the gears grind if the car was low on oil?? And if it was a clutch problem wouldn't I be having the same problem for every gear?
Someone told me the cables might be flexing and I was told that I might as well ziptie my shifter cables together like 98vtec did.
But I would like other insight, I really don't see how the transmission could be damaged, I think it maybe something around the shifter/cables.
But this happened over night, the car drove home fine, i took it apart the next morning to clean the interior and now it's acting like this...
Thanks everyone.
I tried to do a little research yesterday afternoon but the only thing I could find relatively similar was solved by removing the cables and then it worked fine so honestly that didn't even make sense to me lol.
Old 06-13-2010, 06:59 AM
prelude1897's Avatar
Default Re: shift linkage problem?
sounds like your cables may have stretched, cause I've had this happen to 2 of my cars, and I just replaced the cables, and everything worked just fine afterwards
Old 06-13-2010, 05:26 PM
ExtraBlackRex's Avatar
Got a shifter box with cables for u, 60 bucks plus shipping.
Old 06-18-2010, 06:35 AM
'95 BA8's Avatar
No thanks^ and I got it, the cable was snapped, check this out.......
car broke down and got stuck in fourth on the way home sunday, I picked up the only set of cables at the junkyard off an early 90s accord so I need to get some newer cables later on so I can feel safe..
Old 06-18-2010, 06:46 AM
1GPlusSH's Avatar
ah, memories...
Bob_760
13
09-18-2006 05:44 PM
naptownrex
08-20-2006 10:29 AM
BrokenLimits
11
12-07-2005 09:34 AM
bOOsTiNSoHcVtEc
05-21-2003 03:25 PM
Quick Reply: shift linkage problem?
