89 CRX Si B18C1 GSR Swap Project!
Old 05-21-2010, 05:19 PM
  #26
Prodigy [EM2]'s Avatar
Default Re: 89 CRX Si B18C1 GSR Swap Project!
I got a problem guys :/
My injectors are getting power to them and they turn on but now they aren't getting enough fuel to them so the car doesn't stay on? Any ideas???
Old 05-21-2010, 09:49 PM
  #27
GlassHeadlights's Avatar
Main relay?
Old 05-22-2010, 10:30 AM
  #28
No we checked that already. Ahhhh frustrating!
Old 05-22-2010, 01:17 PM
  #29
Wiring, ECU, are you using a resistor box?
Old 05-22-2010, 02:58 PM
  #30
hmmm no i don't think i'm using the resister box since they're obd1 injectors and wiring
Old 05-22-2010, 03:12 PM
  #31
Alright. If the box is gone, make sure you wired it correctly.
Old 05-22-2010, 05:37 PM
  #32
I dont think I have the box, well the car already had a b series motor in it and so i'm not really sure if the resistor box wiring is done right. I was reading that you have to soldier some resister box cables or something like that
Old 05-22-2010, 06:07 PM
  #33
If you have the resistor box it's gonna be to the right of the brake booster. And yeah, check the wiring.
Old 05-30-2010, 02:16 PM
  #34
Finally Got It to turn on right, bought a new fuel filter and fuel pressure regulator and new battery and it turned on fine now lol. Had a crack in the oil pan so I got a new oil pan from a friend and now I just need a clutch wire stay bracket. :/ Anybody Got one?
Old 05-31-2010, 03:12 PM
  #35
dragonsfire776's Avatar
i just bought a '88 crx with a gsr swap in it. not sure why, but the vtec wont work. i went ahead and bought a chipped p72 for it and still cant feel it pull. idk. ill just have to keep working at it. mine dont look NEAR as clean as yours though. nice work.
Old 05-31-2010, 08:00 PM
  #36
Dang that's koo. I bought a chipped p28. What obd is your p72?
Would you like to sell your ecu? I would like a p72
Old 06-01-2010, 12:33 PM
  #37
acurateg21's Avatar
i just got a si crx it has a y8 for 1000 and bought a b20z with gsr head and gsr trans for 400
Old 06-07-2010, 10:21 AM
  #38
THe car is now running, I drove it home today, very loud due to open headers, need to fix the flange. Anyways the car is running fine except I couldn't use my P28 ecu. I have been reading and it seems like you can't be running an ond1 ecu with and obd0 distributor? Can anybody confirm this?
Old 06-07-2010, 11:30 PM
  #39
All IN
Old 06-08-2010, 12:19 AM
  #40
jdm.swift's Avatar
have fun with your project bro cant wait to start mines in a few weeks or soo hopefully lol
Old 06-08-2010, 08:16 AM
  #41
EF9_RIDER37's Avatar
clean falwless bro
Old 06-08-2010, 09:00 AM
  #42
Yeah, the dizzy and ECU have to be the same OBD. Great to hear everything worked out for you! I just got a LS swap for mine for now...eventually I'll get a GSR.
Old 06-08-2010, 09:54 AM
  #43
Ya that's what I was reading (sigh) more problems lol just like any other swap lol. Well I'm going to get an obd1 gsr dizzy today and I'm going to remove the obd0 plugs on the harness and put obd1 ones so it can connect and I can run my P28
One more problem tho guys, my gears barely go in and reverse won't go in, there's tranny fluid and everything, I was thinking that just maybe (hopefully actually) it's the shift linkage is backwards? Any ideas? :/
Old 06-08-2010, 01:52 PM
  #44
Most likely the clutch is out of adjustment.....or the tranny is pooched.
Old 06-08-2010, 03:42 PM
  #45
It's not the clutch, I mean the gears should be able to go in even the car is off and everything but nothing faaaaak! lol. I'm guessing the tranny is done :/
Old 06-08-2010, 08:26 PM
  #46
bump* ?????
Old 06-08-2010, 09:28 PM
  #47
Still might be the clutch in my opinion.
Old 06-08-2010, 11:48 PM
  #48
I'll tryy it out and see, I think I actually used the stock crx one, hmm well i'll try the da one that one that i'm supposed to use lol
Old 06-13-2010, 01:02 PM
  #49
I still can't get my tranny to go into reverse? :/
Old 06-15-2010, 11:33 AM
  #50
Anybody Have any ideas?? I was reading that sometimes a SS won't work with the custom shift linkage for the swap? Is this true????
Quick Reply: 89 CRX Si B18C1 GSR Swap Project!
