Main causes of dropped valves?
Old 03-30-2010, 12:45 PM
  #26
crx=si's Avatar
Default Re: Main causes of dropped valves?
Originally Posted by Teamdiesel
The guy showed me the valve that dropped and the retainer/keepers were still attached perfectly to the valve.
If this is the case, then for sure his friend mishifted the car or something like going from 2nd to 1st or 3rd to 2nd. He overevved the engine by put it in the wrong gear and crashed the valve on top of the pistons.
Old 03-30-2010, 12:58 PM
  #27
Scott_Tucker's Avatar
The head of the valve came off?
Old 03-30-2010, 01:15 PM
  #28
Teamdiesel's Avatar
Yep. came off completely.
Old 03-30-2010, 01:19 PM
  #29
Teamdiesel's Avatar
Originally Posted by NAH2B
sure it can, dropping a valve is the worst thing you can do to a motor. doesnt matter what rpm you are at. maximum distruction will occur haha
what dont you understand?
your not gonna figure out what caused it by making useless posts on the internet....
btw did you ever go to the dyno w/ your pro3 setup?
Hey, i am just helping the guy try to understand what could have happened and if his friend was lying to him. I have not been to the dyno yet as the operator is out of country sailing boats in St. Maarten.
Old 03-30-2010, 01:53 PM
  #30
NAH2B's Avatar
doesnt matter if his friend is lying to him or not, whats done is done....
anything could have caused the valve to drop and playing detective through h-t isnt helping anyone because NOBODY knows what happen except for the driver
maybe your friend shouldnt have let someone he doesnt trust drive his car
and if he trust's him then he shouldnt be second guessing him
Old 03-30-2010, 02:26 PM
  #31
Was piston to valve clearance checked?
Are any of the cylinders still intact or did it break all the valves?
If there are some valves that are still intact, take the damaged piston out so the engine will spin over and either clay the engine or put a light spring (available at any hardware store) in place of the valve spring and check with a dial indicator.
Old 03-30-2010, 05:06 PM
  #32
Teamdiesel's Avatar
This was a 150% STOCK ITR motor. P2V checks were not necessary since the previous head was replace with another 100% stock ITR head.
Old 04-03-2010, 09:07 PM
  #33
tagperformance's Avatar
well in that case maybe stretched rod or rod bolts piston hit valve.
Old 04-04-2010, 12:05 AM
  #34
AllMTRWH0R3's Avatar
Was the block ever decked? I'm sure you "believe it was 150% stock motor" but, I've seen blocks with a 0 deck on them" Just sort of taken back that your main focus of concentration is the head and not the block. I've had dope flowing heads changed from one block to another and they yield different results so in the end it's not the head, it's the block. We're all just trying to help and give you our experience with it.
Good luck,
E
Old 04-04-2010, 12:28 AM
  #35
BigBlock22's Avatar
makes you wonder if the guy knows how to install a timing belt correctly
Old 04-04-2010, 05:10 AM
  #36
Teamdiesel's Avatar
Good luck,
E
Well the car is an ITR that just came from Japan with less than 30K on the speedo. The block is a virgin my friend.
88fourdoor
06-23-2011 05:55 AM
Teamdiesel
04-19-2010 02:38 PM
GReddy SI
10-31-2009 07:19 PM
fms1day
13
07-12-2006 05:29 AM
LsBack
09-19-2004 01:04 PM
Quick Reply: Main causes of dropped valves?
