#2078
#2079
1 Post
I wanted to have room to run as little as 1 deg camber in the rear for setup reasons, so I went with a smaller wheel.
#2080
How do the 12kf 18kr spring rates feel on the street? After looking around this seems to be about the most agressive people tend to go if the car sees any street duty. I know the ep isn't your daily but I know you do occasionally drive it on the street, is it manageable/livable on everyday roads?
#2081
#2082
He might be biased because of it being his car but I'll tell you from having ridden in it many times. It feels very comfortable actually, it doesn't feel harsh and its very smooth. The only thing you might feel is a very occasional quick short bounce at best on some quick dip on the road but its mostly you just feeling the weight of your body coming down quick I guess. It rides just as comfortable as a stock car would IMO just stiffer if you can picture that? He can explain to you why in depth but it has a lot to do with the motion ratios on the EP3 so those high rates don't feel that high. They would be a lot different on another chassis such as an EG/EK/DC.
#2083
1 Post
The car is actually my daily when theres no salt on the road, unfortunately last summer I didnt get it back on the road till June because I was waiting for my shocks to get rebuilt.
#2084
Like Claudio said they actually ride pretty well. When using a high quality shock with good low speed damping without overly stiff high speed damping its possibly to run aggressive rates without it being harsh on the street. Also, the motion ratio in the rear is .56 so the spring is acting at about half its rate at the wheel due to the lever arm created by the distance between the wheel and shock mount.
#2086
#2087
1 Post
Hopefully will be getting the ball rolling here soon. I should be getting my hardware back in the next week or so and will be ordering parts for my rear camber arms tomorrow
#2088
I want to get another EP soon but I want to run 16x8's but that stupid rear trailing arm (from my previous EP) rubs a lot. Wouldn't +42 offset keep that from happening
#2089
What suspension is your EP3 on? and how many inch is it lowered?
I have been doing some research about Ep3 since I might be getting one soon and came upon the issues they have when they are lowered. If you could tell me more about this problem with Ep3, that would be great
Nonetheless, clean EP3 of yours.
#2090
#2092
1 Post
#2093
Share among your friends I want to get a community going and some sort of Fan base. Get some contests/prizes going via www.facebook.com/MisShift as soon as more people start following.
Thx guys for the support
Anyone going to Bonnaroo this this year?
#2094
Earthworm, Im running 16x8's all around.. et38. I'd say I have at least 3-5mm clearance with the dunlop's 225 and they run a bit wide!!! Check the ep thread out!
#2095
Nice. Good set up man. I was torn because CE28's are my lifes blood. If I have to run Enkei's I want them to be different. Possibly the Gold 17x8's with et45.That might be too much though (the offset).
#2096
1 Post
FINALLY an update! I got the first half of the parts in for my rear camber arms The rest should be here in a week or so
Aurora PTFE lined bearings, and Pro Works weld cups
And can anyone guess whats in this package?
