ST Rear Sway Install Issues-RT4WD C.Wagon owners chime in!
Old 03-04-2010, 07:37 PM
eklum's Avatar
Icon6 ST Rear Sway Install Issues-RT4WD C.Wagon owners chime in!
Hello all im goin for a long shot here but i'm wondering if any one with a RT4wd wagon or regular wagon even could post pictures of their ST sway setup or any non,OEM, DA sway setup. heres what my issue is.
when i try to install the ST rear sway i hit the drive train mounts or subframe.
I have been told by a few people that this kit should fit on rt4wd wagons clearing the dif.
I've tried rotating the bar and i got it hooked up this way ( *** backwards )
and then i tried to mount it on the oppisite side of where the instructions say and it works a little bit i can feel a mild push in the rear when i go thru turns.
Its not enough though i had a rear sway on a Ek and it wasnt this big and it pushed waaaaaaay harder.
Something is wrong heres how i had it setup.
This is exactly how the instructions want it put togather..
as you can see the bushing bracket bolts onto the sway bracket on the outside of the bracket. i hoooked it up on the inside of the bracket and angled it properly and i got the endlinks hooked on.
but it still feels awkward. Anyone.. please. help.. lol.
Old 03-04-2010, 07:48 PM
eklum's Avatar
Default Re: ST Rear Sway Install Issues-RT4WD C.Wagon owners chime in!
i figured it would be pointless if i didnt have a pic of how i have it setup now.
looking at this picture i think i realised something. i need to jack up both the trailing arms to make it bolt on right dont i? that will bring the arms up more- seeing it at a rest on the ground made me think of that any thoughts?
Old 03-04-2010, 07:52 PM
racebum's Avatar
you didn't try to install with one wheel up and one down did you? both wheels have to be even so your arms are parallel
Old 03-04-2010, 07:54 PM
eklum's Avatar
ahh but not both in the air sagging ?
so its kinda like what i said about needing to jack up both the trailing arms to make it a shorter distance.
Old 03-04-2010, 08:01 PM
eklum's Avatar
goddamn it im an idiot , its been a long time since i had one of these things . I'll let you know if it fits so us 4wd'ers can have a forsure answer for the rear sway setup problem.
yeep.
search- i forgot about that
https://honda-tech.com/forums/acura-integra-6/how-install-asr-subframe-brace-itr-sway-bar-dc2-integra-2729517/#post41616132
Old 03-05-2010, 10:20 AM
eklum's Avatar
well its hooked onto the most "aggressive" setting and i can still hardly feel it im assuming its not getting the right angle or something.
anyone with a rt4wd wagon and a ST sway help me out! lol this is so annoying
Old 03-05-2010, 10:30 AM
eklum's Avatar
heres more pictures after messing with it this morning.. as you can see i got it mounted on the oppsite side of the bracket. ill post instructions as well in a little bit.I installed the endlinks with both wheels jacked up so it has a load on the sway now but it still doesnt feel good enough!!!
Im wondering if i can just bolt the endlink to the LCA since their both ST wouldnt one think they were ment for eachother? the instructions show the ST LCA but idk if its supposed to mount to it or not..
damn rear cross member.
Old 03-05-2010, 10:57 AM
Meoshe's Avatar
I would try to bolt it to the LCA since you can see it has mounting holes for it and see how it feels and if it clears everything.
Old 03-05-2010, 12:01 PM
TunerN00b's Avatar
Whoa, is that an adjustable length LCA?
Sorry, I can't answer on fitting the ARB...
However, I will state that mounting the endlink in single shear, to an angle bracket also mounted in single shear, doesn't seem like the best idea.
Old 03-05-2010, 12:06 PM
racebum's Avatar
i don't like the way that flange is setting. that 90deg flange you have on the lca bolt should be parallel with the ground. you have it cocked to the side and when the sway bar flexes i wouldn't be surprised if it moved along with it. can you adjust out in order to get it flat and or somehow brace it in place?
Old 03-05-2010, 01:15 PM
eklum's Avatar
i torqued it down pretty hard it doesnt seem to move even with a little sledgehammer action. . . maybe it does work i hit this corner earlier trying to see if the back would kick out and i got pretty sideways. idk im still befuddeled
Old 03-06-2010, 01:13 AM
eklum's Avatar
so i called ST for support and they suggested to use the bracket and that the kit wasnt intended for use with the st lcas ( i thought that was a bit odd. ) . so i tried that any ways after i jacked the lca up to about where the car sits on the ground and then put it in the middle setting the "neutral oversteer setting" and bolted it up a little different than the instructions mentioned . ill post pics tomorow morning , long story short it feels alot better it has a nice push . its kind of peciular
Old 03-07-2010, 01:50 AM
eklum's Avatar
even thuogh st said the lca wasnt ment to be used withe st sway i got it hooked up and it looks like it will be quite functional just as long as it will be setup like mine is you should be good, i feel although its not what i want but maybe i needa get used to it.
(minus those gay brackets on the shock)
Old 03-07-2010, 03:44 AM
Meoshe's Avatar
I know they said it's not meant to be set up like that but 99% of rear arb for our cars are set up like the picture. As long as there is clearance and no binding issues you should be ok.
Old 03-07-2010, 07:44 AM
alphalanos's Avatar
Originally Posted by eklum
This definitely looks better.
Old 03-07-2010, 11:41 AM
eklum's Avatar
welp im settled then- i guess this should help the small amt. of real timers with sway bar issues as long as its mounted the way i mounted mine or similar fashion the ST sway kit works
Old 07-27-2013, 07:27 PM
EFing8's Avatar
bringing this back from the dead.
as a wagon owner, i find this thread useful. I currently have a 23mm JDM ITR bar on my wagon.
Old 07-27-2013, 07:43 PM
90_EX_Civic's Avatar
hmm.... since you bumped it, guess i'll ask a question.
doesn't that L bracket sit on the other side of the shock? wonder if op ever thought to spin his shocks around or swap left to right over and run the L bracket on the other side?
Eyal 951
23
01-10-2008 04:07 PM
young noob
Suspension & Brakes
24
10-22-2006 11:11 PM
Aquafina
Suspension & Brakes
09-29-2005 06:10 PM
Rratedcivichatch
08-17-2002 03:47 PM
Quick Reply: ST Rear Sway Install Issues-RT4WD C.Wagon owners chime in!
