D16Z6 swap into 99-00 civic ek... will it work?
Old 01-06-2010, 05:35 PM
xsuperxsonx's Avatar
Default D16Z6 swap into 99-00 civic ek... will it work?
i have a 99-00 civic ek shell.... its a 4dr automatic... was curious if i could drop D16Z6 from a 94 civic si...???
if so what will i need?
thanks
Old 01-06-2010, 05:41 PM
Seagull Management
94EG8's Avatar
Default Re: D16Z6 swap into 99-00 civic ek... will it work?
You can use the engine, but if you want it to run right you'll need to run an OBD1 ECU and swap in a manual tranny (OBD1 ECU wont control the OBD2 tranny, you'll also have some wiring to do for the distributor, alternator and injectors.
Old 01-06-2010, 06:46 PM
BrayzieEF9's Avatar
It's illegal to put a older motor into a newer car
Old 01-06-2010, 08:40 PM
rivoe302er's Avatar
^^^haha he`s right but eh! you can do it!
Old 01-06-2010, 08:47 PM
ShevyA's Avatar
Yeah and dont forget a manual pedal assembly, if it's MT
Old 01-06-2010, 09:53 PM
Wdpfreak145's Avatar
That is just a bad idea from the start
hondaOchibi7
38
01-21-2011 01:55 PM
phazedd
13
09-05-2009 03:58 AM
Tom123456
12-14-2006 01:11 PM
-slow ej-
06-20-2005 09:03 PM
swoyEKr.
03-27-2005 04:48 PM
Quick Reply: D16Z6 swap into 99-00 civic ek... will it work?
