E85 or 110 octane
E85 or 110 octane
what fuel will give me more power E85 or 110 octane i dont care about price of the fuels just there potencial in making power for naturally aspirated application
Re: E85 or 110 octane
i say e85, both support a ton of power. i made 800 with 110. Now im switching to e85 to see how that rolls since ive talked to successful users.
Rocket Brand E85 is 112 Octane, I am going with this fuel for 2010
http://www.rockettbrand.com/productspecs/specs.html
E85 willl make more power. I switched from E85 to 110 on a car I was tuning (because the 110 was closer). E85 made 20whp more with same tune, just tuned for fuel. 110 was much easier on the ignition system (we ran a larger gap with 110).
was that naturally aspirated or forced induction
Mr. Badwrench
stoich is lower, meaning you can burn more of it, burning more fuel in the same ammount of given air efficiently = more power?
am i right or did infact smoke crack today? hahaa
hell fuel cars are 1.x:1 a/f
never gave it much thought just kinda knew it.
yes but the BTU of Ethonal per LB of fuel is lower than gas....
do you know what the power output of nitro is? lol its crazy stuff!
remember BTU is per LB/gallon ect, if u have a lower stoic, then ur burning more fuel correct? what happens to BTU as u burn more fuel?
E85 any day of the year over a Sunoco or even a VP 110. I've made similar and more power on E85 than C16 on multiple cars. So far 898whp SAE
i run E85 from the pump make 641 whp everyday on a road car. and it was $2.32 yesterday at the pump. and something i have noticed since i have been using it for a while now the engine oil stay's cleaner longer , water temps at cruising are lower that on gas and egt's are retarded low.
because it contains oxygen. C2-H5-O-H is the molecular formula for ethonal.
dashed lines are e85. solid lines are vp race fuel(110 or 112. its been 3 yrs so i cant remember off the top of my head) AFR tuned for both. ign timing left the same so maybe that could have helped the VP. both done on the same day. superflow engine dyno. cbr 600cc turbocharged engine with 19mm restrictor. take it for what its worth i guess.
yep. when you compare the prices of 110 and C16 to E85 its hard not to choose E85 seeign as how you can make similar if not more power than either alternative. almost all the cars out here in Colorado use E85 and daily drive with it because there are so many pumps that carry it here. we made just under 600 and drove it around all the time getting around 29mpg as long as w dont get one it lol. feels good to only have to spend around around 25 bucks for a full tank before you head to the track or for a drive around town instead of around 120 bucks for C16 lol.
