1996 honda civic 4dr. having problems with all 4 windows?
Old 11-25-2009, 08:37 AM
Silvertc's Avatar
Default 1996 honda civic 4dr. having problems with all 4 windows?
i just bought a 1996 honda civic lx 4dr. it sat for couple months from previous owner. i just got it running again. none of the windows will go up or down.
-I checked all fuses for each individual window under the dash. all are good
-Checked the power fuse for power windows under the dash. good
-Checked the power window fuse in the engine bay fuse box. good
What else could be wrong? or what else should i check?
Old 11-25-2009, 08:44 AM
1badascivic's Avatar
Default Re: 1996 honda civic 4dr. having problems with all 4 windows?
did u make sure the driver window swich is plug in? some time the window will sicked if it sits try to push down a lil not alot to see if any thing happends
Old 11-25-2009, 09:45 AM
Silvertc's Avatar
ill check the switch, i didnt follow the rest. the window will sicked if it sits?
Old 11-25-2009, 09:48 AM
Hill4589's Avatar
Sometimes the window will stick, if it sticks, try to push down a little, not a lot, to see if anything happens?
Old 11-25-2009, 11:22 AM
Silvertc's Avatar
oh lol ok got cha. alright ill try that, honestly tho it just doesnt even sound like any of the window regulator/motors are even like attempting to move at all
Old 11-25-2009, 12:51 PM
Master Detailer
98civdx's Avatar
have you pulled the door pannles and check everything out?
Old 11-25-2009, 02:48 PM
F4MzEkSOL's Avatar
well i have the same issues with my 4 door but actually i found wear and tear at both harnesses behind the fender so then i bought these doors cause i had to replace both my doors on the passenger side and then i found out the wires started snapping off the harness which is best i have to rewire the harness again with new civics from the junk yard now everything seems to works fine btw also check the main window relay and dont forget to check wiring connection behind the fenders on both front doors they tends to snap from time to time and then there would no more connection
my car is 96 4 door and i found this out but going thru the harness
Old 11-25-2009, 02:49 PM
F4MzEkSOL's Avatar
ill have pics up later if youre still confused of wats going on
Old 11-25-2009, 09:04 PM
itsnotfast's Avatar
EKs are notorious for the wires pulling out of the plugs between the door and the car inside the rubber boot. They get brittle and snap mine did the same thing I cut one out of a car in the junk yard and soldered it in works fine now. I'm betting its the one in the driver door.
Old 11-25-2009, 09:09 PM
H-T White Ops
NOFX's Avatar
Silvertc, did you try all the switches and not just the driver switch?
I've also never heard of any common problem about wiring pulling out of the plugs or boots for these cars. I've owned two and my boyfriend used to have one too. I work parts and have for years and I've never had a customer come in with that problem either.
Old 11-25-2009, 09:17 PM
itsnotfast's Avatar
Maybe it's not that common or it could be because I live at the beach on the east coast and the salt air eats the wires up faster. I know 4 or 5 guys that have had this problem.
Old 11-25-2009, 09:18 PM
itsnotfast's Avatar
My car also sat for about 5 years.
Old 11-25-2009, 10:41 PM
H-T White Ops
NOFX's Avatar
I'm from Dover, DE. My car was first registered in Salisbury and I bought it at Price Honda in Camden. I also got my other Civic (a '97) from Price Honda.
I had this current car in DE for maybe three years or so. Then I drove it to CT and then WA, where I live now.
I used to work parts then and was big into 6G Civics then too. Never heard about it then either. Weird you've experienced it in so many cars.
I'd say this might be it, but you mentioned your friends' cars too. I have no idea.
Maybe like you said it has something to do with being right up near the beach.
Old 11-26-2009, 08:03 AM
F4MzEkSOL's Avatar
i live in cali and the wires on this car seems all to snap off around the booth area, well atleast its a new issue we found it tends to snap from time to time of the doors being open and close for daily use
Old 11-29-2009, 05:57 AM
Silvertc's Avatar
yes i checked all four, tried lock and unlock windows nothing. took apart panel switch is plugged in. i think its a wiring problem or the driver switch is completely bad..
N0zo
Honda Civic (2006 - 2015)
04-06-2017 01:53 PM
s4325
08-04-2010 09:31 PM
nos.mike
04-20-2010 01:33 PM
tiptopEBPcivc
12
08-15-2009 03:26 PM
int3gra07
09-15-2005 05:52 AM
Quick Reply: 1996 honda civic 4dr. having problems with all 4 windows?
