Write-Up: DIY Front Wheel Bearing Replacement
Old 12-31-2009, 01:20 PM
  #26
Clipsed's Avatar
Default Re: Write-Up: DIY Front Wheel Bearing Replacement
lolz, I got it off really quickly believe it or not!
Clipsed is offline
Old 12-31-2009, 01:30 PM
  #27
Keyboard Humorist
4drEF's Avatar
That air arc looks like a complete mess! Obviously it turned out fine, but I'm curious how that thing looked step by step.
Does it create much heat?
4drEF is offline
Old 02-24-2010, 04:32 PM
  #28
DO IT ON ALL FOURS
OneBadTurboCRV's Avatar
Yes, a lot of heat. It is just like welding, so you HAVE to have the skill set to use it. It is very easy to eat away at the underlying metal. I am a Millwright Welder by trade; I do this almost every day at work. So for me, it is not a problem.
OneBadTurboCRV is offline
Old 02-24-2010, 04:50 PM
  #29
hailchristian's Avatar
Great write up. I was just looking into how to go about doing my wheel bearings when i upgrade to dx/si hubs.
Can this please go into the FAQ?
hailchristian is offline
Old 04-28-2010, 10:53 PM
  #30
ntoxicatedtigah's Avatar
hey guys, i noticed when i pulled my hub off, the back side of it had a ring around the inside of the hub. Not touching the bearing but outside of it. On the 2nd to last picture, step 10, on this write up, I noticed its not there. Is it bad if you dont have it. I tried to find a diagram of it, but no honda service manual or Alldata has a picture of it.
ntoxicatedtigah is offline
Old 04-29-2010, 11:54 AM
  #31
The Destroyer's Avatar
Are you talking about the dust cover? I wouldn't run without it.
The Destroyer is offline
Old 04-29-2010, 12:21 PM
  #32
idk if its a dust cover or not. its a ring. and i see alot of these knuckles/hubs without them.
Old 05-02-2010, 11:37 AM
  #33
DO IT ON ALL FOURS
It is a protective cover. The problem is if you do not remove it when you have a B-series swap the axles will bind when you tighten up the axle nut. You will be fine if you pop them off and run with out them.
Old 05-02-2010, 02:49 PM
  #34
So its better to not have it. And yes its a b swap.
Old 05-02-2010, 04:19 PM
  #35
DO IT ON ALL FOURS
Not necessarily better, just 90% of the time the axles will bind if you don't remove it and you have a B-swapped car (obviously because the axle's cup ends are larger).
Old 05-03-2010, 07:04 PM
  #36
Gmoney400's Avatar
thanks so much ill be printing this page out...getting some serious noises from my bearings haha time to come out...this will save me a nice chunk of money
Gmoney400 is offline
Old 08-08-2010, 07:31 PM
  #37
jdm27ef's Avatar
I need help on this..... my wheel bearing is so bad the inner race near the axle is actually split in half. 0.o!!!! now since the inner race is pretty much messed up, the outer race is stuck inside the knuckle...... is there a way to get the outer race off the knuckle? the inner race is pretty much off the bearing assembly, there is nothing to hit to get it out. Please help! i need my car to get running again by tomorrow.
jdm27ef is offline
Old 03-20-2011, 08:12 PM
  #38
95B18BTurbo's Avatar
I know this thread hasn't been touched in awhile, but it helped me a whole hell of a lot today since I don't have a press and all the shops were closed! It's still a pain and took most of my day, but it got the job done needless to say with out a press! Kudos to the guy who took the time to write this!
95B18BTurbo is offline
Old 03-20-2011, 09:01 PM
  #39
DOHC_Hatcher's Avatar
you can use a air hammer with a chissle bit to get the inner race off the hub
DOHC_Hatcher is offline
Old 04-20-2011, 06:15 PM
  #40
DO IT ON ALL FOURS
I know this is way too late to help, but... it may help someone else. The only easy cheap way to do this is by using a cape chisel. You may be able to use a cold chisel but risk doing more damage than good.
Old 05-01-2011, 08:22 PM
  #41
pappie1's Avatar
Had to say..... very handy writeup. about the inner racers..... the grinder is gotta be the easiest way to go about removeing it from the hub. Took a only 10 minutes max..... you really dont need to cut all the way through. Just paper thin. the heat from the grinder helps a ton. then just use a prybar to crack it loose.
Very handy writeup
pappie1 is offline
Old 05-11-2011, 08:57 PM
  #42
sde780's Avatar
I did this and the inner race did not turn blue/purple when you get close to the hub!
I looked very carefully and didn't notice any difference until I felt like I cut too much. Got a small gouge on the hub now, will this affect anything?
I ended up using a small screwdriver and using it with a hammer at the place where hub and inner race meet...it pushed it out enough to get a slide hammer on and got it off.
sde780 is offline
Old 05-27-2011, 12:20 PM
  #43
DO IT ON ALL FOURS
No, it will not affect a thing by having a small gouge.
Old 01-01-2012, 03:24 PM
  #44
DO IT ON ALL FOURS
Updated the process a touch and added some information.
Old 01-01-2012, 03:50 PM
  #45
Thorshammer's Avatar
Excellent write up. Very informative and helpful.
Thorshammer is offline
Old 01-02-2012, 08:05 AM
  #46
redef90si's Avatar
Great DIY!
redef90si is offline
Old 01-02-2012, 11:03 AM
  #47
artiecubz's Avatar
artiecubz is offline
Old 04-16-2012, 11:16 AM
  #48
shiroun's Avatar
I know i'm bumping from the grave, but this IS a great writeup. Got quoted $100 to transfer wheelbearings from 1 spindle to another, I'm thinking about simply doing it myself in one go. Saves me $100!
shiroun is offline
Old 04-17-2012, 07:57 PM
  #49
DO IT ON ALL FOURS
It's not bad to bump Write-Ups because it helps people find things they are too lazy to search for.
As far as your problem - you can't just "swap bearings" due to the snap ring. This is why the inner race comes out when you hit the hub out. Read the entire write-up and if you still need help just post up and I will try to the best I can.
Old 06-23-2012, 09:51 AM
  #50
LowNstocK's Avatar
great write up, working on mines now after getting quoted 400 to replace both wheel bearings!!
Thanks!
LowNstocK is offline
Quick Reply: Write-Up: DIY Front Wheel Bearing Replacement
