| Welcome to Honda-Tech! | ||
#1 |
1982 Honda Civic |
I just bought a 1982 honda civic 1300. I am trying to find out if this car came from the factory with a ek1 motor .the guy I bought it from said it was the stock motor but he was the third owner. i think somewhere down the line it was changed. the numbers on the motor are EK1 5530054. the best I can tell is thats a 1.8 and the civic didn't have that engine as an option in 82. I really need to know more about this motor like what to set the valve lash, spark plug gap and I would like to change the timing belt.
any help would be great. Thanks, James |
#2 |
The motor is not stock. Its out of a Prelude or Accord.
timing belt adjustment/pivot belts - torque to 31 ft lb. cam gear - 22 ft lb. crank gear - 83 ft lb. valves: intake and aux: .12-.17 mm clearance exhaust: .25 - .30 mm All this from a Factory Honda Service manual. |
#3 |
ps - plug gap is 1.0 to 1.1 mm
#4 |
1982 Honda Civic |
Thank you for the info. I did order a manual for this car but it didn't cover this engine.
I guess I will have to order 1 for the accord
#5 |
1982 Honda Civic |
I keep finding more about this car. the shifter *** says 1-4 but I found 5th gear today.
#6 |
11:11
I'll have to check, but I think I have a book for the first gen accord if you didn't already order one otherwise.
#7 | |
1979 Honda Civic |
This would be the first gen Accord/Prelude. 1976-1978 had a 1.7L EM-1 engine. More specifically on the Accord it would only be the Accord engine from 1979 to 1983. If you want/need a specific year of Accord/Prelude:
1979 - 1000001 and up 1980 - 2000001 and up 1981 - 3000001 and up 1982 - 4000001 and up 1983 - 5000001 and up If it qualifies for the 1983 year, it would only be an Accord engine. I have the EK-1 from a 79 model Accord in mine. Quote:
Check your chassis code. SL-431 is a 1300 4 speed. SL-532 is a 1300 5 speed. SR-332 is a 1500 automatic. SR-532 is a 1500 5 speed SR-533 is a 1500 5 speed and the model would be GL Hope that helps the break down a little more in depth for you.
MY "OFFICIAL" CVCC SITE!!! |
#8 |
1982 Honda Civic |
Thanks guys.
I now know that I have an 82 civic HB with a 83 accord engine. my guess would be that it has the accord 5 speed sence the vin # says it came with the 4 speed. |
#9 |
1979 Honda Civic |
Glad I could help. Well, if you got that info from the info I posted.
| Tags |
| 82, 83, accord, cam, civic, ek1, engine, forums, gap, gear, honda, motor, plug, prelude, spark |
