help with my civic timing
i have a 94 honda civic coupe and it has a single cam and i need to set the timing to put my timing belt its seems hard cause the motor is in the car. so i have the timing belt on just not on the cam gear. now what do i do how do i get to it or whats the easiest way pics will help alot please..
i no u have to set piston number 1 to tdc and................................help
im sure its the timing car cranks up good but kind throwing air out or kinda backfires once
Re: help with my civic timing
geta haynes repair manual. makes it so much simpler. their is marks on the camshaft sproket and marks on the crankshaft sproket. take out number 1 spark plug which is located closest to your timing belt. take out the plug and find something to go into the whole and rotate the engine slowly from the crank useing the bolt that held the harmonic balancer in place.once that stick goes as high as it goes and no more. than the engine is at TDC. then on the camshaft sproket it has 2 marks one pointing left one pointing right and on top of the sproket it says top and TDC. then put on you belt.
OR turn the camshaft and take off the disturbutor cap and turn da crank untill the rotor points at the number 1 spark plug wire.
Good luck Man !
Good luck Man !
I think hes saying he adjusted the ignition timing at the dizzy. Youll want to set that back where it was after you do the belt. A haynes or better a helms will be you best friend for any job you have.
ccdc2223
06-27-2012 09:21 AM
