Acura MDX / RDX
01 van cel
Old 10-02-2009, 06:27 AM
Frank Allen's Avatar
Default 01 van cel
have 2001 honda van, cel came on, codes reval a problem with the fuel evaporator system, what do i do??
Frank Allen 2001 hoda ex van
Old 10-02-2009, 08:40 AM
NDNV's Avatar
Default Re: 01 van cel
The diagnostic procedure depends on the EVAP code. Is it P1456 or P1457 (2 most common codes) as it matters to which end of the vehicle to troubleshoot.
In the meantime, you should make sure the gas cap is tightened at least 3 clicks each time - otherwise you may get an EVAP code. Try this and run for a few driving cycles to see if CEL will go away. This is assuming you do not smell a gas leak of course.
bcumby
Honda CR-V & Element
03-01-2017 06:41 AM
bopbop93030
11-08-2008 03:02 AM
dcfour
04-04-2005 06:34 PM
AamirCWITR
06-25-2003 01:47 PM
Quick Reply: 01 van cel
