Official: K24 block, K20 head build info
Old 07-03-2013, 07:14 AM
  #51
tobesta2003's Avatar
Default Re: Official: K24 block, K20 head build info
My plan was to do a k24/k20 frankie but my question is what would be the best k24 bottom end to use? Would it even matter since the head would be changed? or would it just be wise to stick with the k24a2 top end since i have one sourced? i want to make sure i keep true vtec and the car is for street/road track use.
Old 07-05-2013, 07:41 AM
  #52
4LugHero's Avatar
Best K24 block to use for that swap would be the K24A2 TSX block. Stronger internals allow it to handle more power with fewer mods than other K24 blocks. And about the K24A2 head, I'd say it depends on price vs power gain. A good K20 head, either Z1 or Z3, will net you more power and torque than a K24A2 head, but the K20 head will most likely be more expensive than the K24 head. All three cylinder heads mentioned have true i-VTEC, so you'll keep that no matter which head you choose.
Old 07-05-2013, 03:28 PM
  #53
been there done that
doood's Avatar
if you just want to drop it in and not mess with internals, the k24a2 would be the best option.
if you're doing a complete build and replacing internals, the cheapest, cleanest condition k24 block is the way to go.
Old 07-05-2013, 06:25 PM
  #54
rexB20vtec's Avatar
my friend is doing the same swap but he is putting it in a 8th gen accord k24 he wants to know if he can use his stock ecu or use a 8th gen si ecu, any info will help thanks
Old 08-07-2013, 03:52 AM
  #55
SlowWhite_EG's Avatar
Building mine at the moment going for 300whp on 91 pump gas
K24a1 87.5 bore
Wiseco 12.5:1 pistons
Eagle rods
K20z1
Twm 52mm itbs
Injector dynamics 1000cc
Supertech dual springs
Supertech flat valves
Supertech bronze valve guides
Supertech titanium retainers
Skunk2 spring base kit
Skunk2 stem seals
Skunk2 tuner stage 3 cams
PML 4-1 headers
3" Catback
255 LPH walbro intank fuel pump
300 LPH Bosch 044 external Fuel Pump
Gonna get it tuned by yosolo
I finished building the engine
Im working on shaving the bay
And full tuck hopefully will be together running
And tuned by november
Old 08-08-2013, 04:00 PM
  #56
jdmdomo's Avatar
No one , with pictures of this fcking sick built's ?
Come on H. T.
Old 08-28-2013, 03:47 PM
  #57
lxrd_vtec's Avatar
Why would one do a k20/k24 swap? Does the K24 have a stronger block than the k20 or something?
Old 08-28-2013, 05:30 PM
  #58
doug118's Avatar
What's better? 2 liters or 2.4 liters?
Old 08-29-2013, 09:59 AM
  #59
Crazy Honda Guy
Deetz's Avatar
The 2.4L shortblock is larger, i think the answer is obvious, as well it's capablilities of making more power. It's no secret
Old 08-29-2013, 01:43 PM
  #60
lxrd_vtec's Avatar
I had it backwards, for some reason I thought a k24 head on a k20 bottom smh. But i dont know anybody that has a set up like this so I don't really know much about these swaps.
Old 08-29-2013, 04:35 PM
  #61
doug118's Avatar
Old 08-29-2013, 04:36 PM
  #62
lxrd_vtec's Avatar
Originally Posted by doug118
Ha ha c'mon man
Old 09-03-2013, 09:10 AM
  #63
Builda'Teg_92's Avatar
Ok so im taking an engine building class at school and wanted to assemble a k24 shortblock: K24a4 block, 04-05 tsx rods, and 09 tsx pistons.
So basically my question is.....Are ALL tsx rods and ALL tsx pistons compatible as far a wrist pin diameter goes? without milling the small end or anything like that? I know about valve clearance being tighter with older tsx pistons but aside from that will this work?
04-05 tsx pistons with 04 tsx pistons attached, I would like to change them to 09 tsx pistons. That's the plan.
Old 09-18-2013, 11:33 AM
  #64
400whp_94teggy's Avatar
JDM!!!!!!!
Old 10-13-2013, 07:59 PM
  #65
ElementAK's Avatar
I just built this:
K24 (Element block, not the K24a4 TSX block with piston squirters.)
K20a2 head
Wiseco 12.5:1
Scat Rods
PRB Intake with hondata spacer
DC 4-1
AEM CAI
KPro
And more but thats the basic picture for now.
After initial break in the head was pulled off for a complete build.
Old 07-10-2014, 06:19 AM
  #66
ChrisSA's Avatar
Hi guys... i know the last post was a long time ago, but i live in africa so am a little behind. i have access to a jdm k24a from a honda odyssey (absolute model) complete motor will cost me around 1600us 20000namibian dollars. Is this a useable version with my k20a3(03' ctr) and or my friends itr dc5. Please some1 give me some info please bare in mind we do not have acuras here. But we have accords with k24's and crv's with k24s
Old 12-06-2015, 09:15 AM
  #67
erbavour's Avatar
I would go with the accords or crvs k24s. Accord would be like an american tsx.
Old 02-27-2016, 03:57 PM
  #68
2005RSX's Avatar
Hey guys new to everything and I could really use some help I have a 2005 rsx and has a decent amount of miles 190k base model I'm
On kind of budget and was wondering if you anyone could help me with a list on what I would Need to build the motor completely what parts i would need and I also wanted to a budget build in the mean time
Things to get more horse power out of her while I gather parts for the big build if it makes sense I appreciate any help I can get don't know who to talk to or ask
Old 05-15-2016, 09:38 PM
  #69
Ryman797's Avatar
Hey guys, sorry to bring this back but my brother has been in the process of piecing together a k24a2 with a cammed k20z1 head and the mechanic was worried about the clearance between the valves and Pistons. The k24 is completely stock except for a z1 oil pump. The cams he's using are the S2 turbo cams, I forget which stage. Thank you for the help
Old 01-13-2019, 05:50 AM
  #70
ncaccordk24's Avatar
Thanks for the info!!! Pretty cool that you got it worked on by RLZ engineering
Old 10-23-2019, 09:59 PM
  #71
Batillac's Avatar
I realize this is an old post, but what it the go-to K-series for n/a and turbo? I came from building B-series motors and was curious if the K-series were better with franking different heads with other blocks like the B-series.
Old 01-27-2020, 07:09 AM
  #72
chris62900's Avatar
To continue:
I have a k24a2 block on a K20z3 head.
Block:
08' TSX
Wiseco 11:5 comp
Eagle H-Beam Rods
Acl Race Bearings
255 fuel pump
Stage 2 Action Clutch
ARP Head studs
Eagle ESP Crank
Head:
Toda N2 Camshafts
Supertech Valve Package 92 lbs
7 degree keepers
Ferrea 6000 Intake/ Exhaust Valves
Intake:
RBC
70mm tb on a velocity stack
Fuel:
RDX Injectors (i'll probably run max duty cycle on these injectors and need bigger ones)
KTuned Fuel Rail
Currently getting built and I am expecting 260-270 HP All Motor
Old 10-26-2020, 02:19 PM
  #73
Chaseincolor's Avatar
Great info in here! Looking at building a K24/K20 for my s13.
Old 02-28-2021, 05:46 PM
  #74
Clarence Leon's Avatar
Originally Posted by chad
I'll start:
k24a4 block
2009 TSX 11:1 Pistons
2006 TSX Rods
k20z3 head PNP by me, RLZ Valve Job
k20z3 cams
K20a Intake Manifold and Tbody
This is a 100% HONDA part build minus bearings.
Hondata KPro
Tuned by Howard at RLZ on DYNAPAC
233 hp and 172 tq
Reving to 8k
Dyno'd at Darrel *** Racing Air Fuels tuned by me
243 hp and 190 tq
8 Hours on the engine so far, ROAD RACE HOURS NOT DAILY DRIVING, I do not know milage because i have a 2006 RSX Type S tranny without speedo.
Will post dyno's when I get them scanned.
THIS IS FOR BUILD INFO AND DYNO SHEETS!
Please follow TOS in this thread, ie NO FLAMING!
retuned at RLZ in July and made 232 on their dyno. injectors took a dump on me first lap out at CMP in kershaw SC. car missing and short shifting at 6-7k i still ran a 1.49.7
retuned week of oct 5th 2009....power was the same, up'd the rpms to 8200. took it to VIR again for oct 10-11 NASA MidAtlantic weekend. Ran a 2.10.2 on 3 year old hoosiers and NO AERO to the car and stock lsd....lsd aero and tires will net me at least 3 seconds a lap, i just don't have the 4000 to dump into all of that right now!
I know alot of years have passed lol. But when you put the 09 TSX pistons did you end up machining or taking a bit of material off of the piston to get proper piston to head clearance? Thanks
Old 10-06-2021, 12:55 PM
  #75
Negative_WVC's Avatar
Great info and power numbers!
Quick Reply: Official: K24 block, K20 head build info
