Official: K24 block, K20 head build info
I'll start:
k24a4 block 2009 TSX 11:1 Pistons 2006 TSX Rods k20z3 head PNP by me, RLZ Valve Job k20z3 cams K20a Intake Manifold and Tbody This is a 100% HONDA part build minus bearings. Hondata KPro Tuned by Howard at RLZ on DYNAPAC 233 hp and 172 tq Reving to 8k Dyno'd at Darrel Cox Racing Air Fuels tuned by me 243 hp and 190 tq 8 Hours on the engine so far, ROAD RACE HOURS NOT DAILY DRIVING, I do not know milage because i have a 2006 RSX Type S tranny without speedo. Will post dyno's when I get them scanned. THIS IS FOR BUILD INFO AND DYNO SHEETS! Please follow TOS in this thread, ie NO FLAMING! retuned at RLZ in July and made 232 on their dyno. injectors took a dump on me first lap out at CMP in kershaw SC. car missing and short shifting at 6-7k i still ran a 1.49.7 retuned week of oct 5th 2009....power was the same, up'd the rpms to 8200. took it to VIR again for oct 10-11 NASA MidAtlantic weekend. Ran a 2.10.2 on 3 year old hoosiers and NO AERO to the car and stock lsd....lsd aero and tires will net me at least 3 seconds a lap, i just don't have the 4000 to dump into all of that right now! |
Re: Official: K24 block, K20 head build info
will update this post with numbers
K24A4 block bored to 87.5mm crank micropolished and mic'd by me K20A2 head Replica big tube header CP 12.5:1 pistons IB I beam rods drag cartel stage 4 cams supertech VT rc 550cc injectors ported RBC or Skunk2 manifold (only thing left) k-pro tune emailed from JL in EK4 SIR with jdm EP3 CTR trans (i think its going to be too short, need usdm FD) looking for ~305whp |
4 Attachment(s)
Ok finally done with the build there are 4 dynos starting from where i got it since today
This thing REVS like a bike and it has lots of tq Heres the dynos: Made 274.8hp and 200tq on the last run will post that dyno sheet tomorrow Attachment 468388 Made 293.1 and 216tq the most i made that day was 294hp Attachment 468389 new numbers Attachment 468390 Attachment 468391 Heres the list of parts: Block k24a4 87.5 bore honed and hot tanked Wiseco 87.5 12.5 cr pistons with deep pocket valves BP Pro I beam rods crank was balaced and polished and knife edge acl race series bearing Head Blueprint stage3 cams IPS retainers and spring combo Im still in the stock valves Bolt ons rbc manifold Hytech replica header 3.0inch exhaust CAI AEM EMS 550 inj The runs were done on a DYNOMITE with 93oct Thanks to IMPORT AUTO PROS for tunning and building this motor and to ROBBIE from blueprint for the good prices and quality parts |
Originally Posted by PirateMcFred
(Post 39623131)
87.5mm K24A4
stock K20A head, PRC IM, and 62mm TB 12.5ish compression "stage 2" cams/valvetrain Custom K24 header and ø2.5" full exhaust forged rods/pistons 410 injectors 91 octane econogas http://i37.tinypic.com/2qm2h6p.gif I'll see if I can dig up a RBB IM dyno that made 260whp 210wtq... |
Nice
:bump:
For some sweet builds. |
hi im new to the site and i am a k24 enthusiast. i really beleive that what you have done is sick bro thankd for opening perspectives man...
the k24a4 is the only k24 that a real vtec head fits on im guesing?
what did the k24a4 come in? i see the its in the latest crv. anything esle? |
The k24a4 block is the accord block thats the block i have in my fg2 but has tsx pistons and rods to make it a tad bit stronger
nasty numbers...some really quality builds
is the K24a4 block better to build off of then the a1? i see that you guys are using the A4 block. I plan on using the TSX pisons and rods in my build, but just wanted to know which block is better to start with, or was affordability a part of the block choice?
I just sucked up some water and bent my rods and just hydro locked my engine.... :( so what im doing now is dropping a K24 TSX block into my K20 head. Any advice on what what could go wrong?
Does anyone know were to find the head code on a k series head?
Im also looking for the head code on the k series head, does anyone know where to find one?
my parts list build, hoping for 300whp/200+tq...should be close!
K24a1 Block, stock bore 87mm...if block needs it, will bore to 87.5mm.. Supertech Valvetrain Blueprint I-Beam Rods Blueprint Flat 0.5mm Valves Wiseco 12:5:1 Pistons KRRH Skunk2 Mega Power "RR" BC Stage 3 Cams ported RBC |
Originally Posted by nahonda04
(Post 43210608)
Originally Posted by lzyga09
(Post 43322112)
yea you should be very close to 300 depending on the humidity.
going to pick up the freshly polished and scoped crank and the welded, honed and decked block in 2 weeks |
do you know what your going to be reving to? thats going to play a big part in your hp
(Post 43386326)
La funda must have been spent on most of these builds......
adding ID725's, walboro 255 and e85 to the build now as well!!
keep them coming what are most people revvin to ?
Originally Posted by legomytego
(Post 43927844)
keep them coming what are most people revvin to ?i
04 tsx motor head never taken off the block (train wreck motor )
04 k24a2 1000cc id injectors rrc manny spoon euro r t/b 70 tapered to 64.5 ips kme cams Eibach evs springs type s 50 vtc hytech type s oil pmp SMSP 4-2-1 HEADER smsp cat, resonator , muffler ,and 3 inch piping karcepts intake 93 OCT 273HP / 216TQ |
bangin info
