00 Civic - No Spark, No Start.
Old 07-19-2009, 10:30 AM
RMX_EF9's Avatar
Default 00 Civic - No Spark, No Start.
Ok Guys Here's The Rundown.
Within a two week period Ive:
Replaced Spark Plugs, Replaced Radiator
Replacing The Radiator Solved My Overheating Problem.
The Day I Installed The Radiator, I drove it Around To Test The Overheating - No Problems There, So I Stop by my moms To Help her With something.
As Soon as I Pull Up to her house, the Car Drops to less than 500rpms and the motor shakes extremely hard, then stops. So I restart the car -same thing happens.
So I Pull Spark Plugs 2 and 3 and there wells have a little water in them. No biggie right ? I Grab some towels, soak up the little water that was there, and let it dry out while I'm helping my Mom.
I go to leave, Now The Car Won't start at ALL.
Ive Tested:
Timing Belt - OK
Relays and Fuses - OK.
Battery - OK.
Compression - OK.
Spark at Spark Plugs - FAIL.
Fuel Getting where it needs to go - OK.
I Also Pulled the distro and checked for signs of burnouts, and the damn thing looks brand new !
After researching this ... I'm leaning toward Distributor has died. I'm the average working man, and dropping 200 bones for a distro right now would kill my pockets
Any Idea's to anything else it could be ? Im really hoping its something as simple as a lose wire or something :S
Old 07-19-2009, 10:38 AM
RMX_EF9's Avatar
Default Re: 00 Civic - No Spark, No Start.
Also Forgot To Add This In ...
I Did Not Get a "Check Engine" Light when This Happened, But I think Im Supposed to have it come on, then Cut off after a second or two if I turn the car to the "ON" position and if everythings ok CEL - wise. This does not happen at all ...
Old 07-19-2009, 11:05 AM
RMX_EF9's Avatar
Any Takers ???
Old 07-19-2009, 11:07 AM
Former User's Avatar
CEL: Is fuse 25 under the dash blown? Is the CEL bulb blown?
No spark: With the key in ON(II), do you measure battery voltage at the BLK/YEL wire connected to the coil and ICM in the distributor? What voltage do you measure at the YEL/GRN wire attached to the ICM?
Old 07-19-2009, 11:20 AM
RMX_EF9's Avatar
Ok, Changed Bulb Out ...
Throwing A Code 6 - Water Temp. Sensor.
Would This have Anything to do with a no spark, no start senario ?
I Don't believe so .. but ...
Old 07-19-2009, 11:27 AM
Code 6 won't cause a no-start.
Check voltages in the distributor.
Old 07-19-2009, 11:38 AM
RMX_EF9's Avatar
K ...
P.S. Thanks RonJ
Old 07-21-2009, 07:50 AM
RMX_EF9's Avatar
BUMP !!
Replaced the coil ... Got spark again but ...
NO START !
can plugs and wires get so messed up that they won't provide enough spark to fire the plugs ???
Old 07-21-2009, 08:17 AM
Does the fuel pump prime?
Did you reinstall the plug wires in the correct firing order on the distributor cap?
Any new CEL codes?
Old 07-21-2009, 08:56 AM
RMX_EF9's Avatar
Any new CEL codes?
Yep, The Fuel Pump Primes ... No New CEL Codes Though.
This is probably stupid of me to say without have changed out, but My wires did get jacked the hell up, seems as though the plastic boot fused with the plugs I had put in before all this happened ...
Im an idiot. lemme change my plugs and wires before I start asking more questions haha
Old 07-21-2009, 09:01 AM
nothing_shocking's Avatar
this sounds exactly like what's going on with my friend's 200sx. i'm gonna guess it's your wires too because that's the only thing we haven't tried on his SR20DE.
Old 07-21-2009, 09:04 AM
RMX_EF9's Avatar
If he's anything like me, he's ready to kick the car or pull his hair out ... haha
Old 07-21-2009, 09:09 AM
actually, he was about to be stupid and sell the car for $1000. he's on his 3rd engine in it. 2 of them (including the one in it now) are JDM. I managed to talk him out of it by agreeing to help him fix it after he helps me fix mine, lol.
Old 07-21-2009, 09:10 AM
RMX_EF9's Avatar
[QUOTE=nothing_shocking;39324973]actually, he was about to be stupid and sell the car for $1000 ...QUOTE]
Old 07-23-2009, 09:25 AM
RMX_EF9's Avatar
UPDATE.
WTF. Got the car started FINALLY.
Started it up and let it sit for a minute ... started overheating.
Added more coolant.
Overheating stopped.
Started car several more times. Even drove it around town !
Get back to the house, and went in the house. less than an hour later, the Motherlicker won't even think about starting.
Whats been replaced on car so far.
Radiator.
spark plugs.
spark plug wires.
Ignition coil.
Full Tank of Gas.
I know this thing will run. I drove it around after replacing the plugs and wires !
Old 07-23-2009, 11:22 AM
have you checked to see if the battery and alternator are good? get a volt meter and test the battery for around 12-14 volts with the car off... idk... lol.
i know you said the battery is ok, but you don't say how you checked that.
Old 07-23-2009, 12:24 PM
RMX_EF9's Avatar
Oh, a Buddy of mine works at a custom car audio shop ...
he brought over some special tool [ I have no idea the name of it ] hooked it up to my battery, and it displayed the voltage coming out of the battery ... That tool looked mad expensive btw ... haha
Old 07-23-2009, 01:08 PM
happyabortion's Avatar
so the motor spins but not starting? have you checked to see if you've lost spark again? is the fuel pump still priming?
it was probably a volt meter then. hmm.... idk what else to tell ya, sorry.
Old 07-23-2009, 01:22 PM
B18CivicEJ8's Avatar
Originally Posted by RMX_EF9
UPDATE.
Added more coolant.
Radiator.
spark plugs.
spark plug wires.
Ignition coil.
Full Tank of Gas.
Sounds like a bad Ignition Control Module.
Old 01-26-2014, 10:44 PM
EkCoupe2000's Avatar
I'm having the same problem mine has no spark and the fuel pumps not priming but I've checked all my fueses grounds and main relays. Everything's fine. Spark plus dizzy and wires are brand new, brand new battery and alt... Anyone have any ideas?!?!?
Old 01-27-2014, 05:43 AM
What car/engine/ECU? CEL stay on steady with key in ON(II)?
Old 01-27-2014, 12:55 PM
Skelley1980's Avatar
Does the car crank and not start. Distributor. Mine was 400 bones don't feel bad. I had the shop do it cause you have to get it timed even if you put one on yourself.
Old 07-09-2017, 11:38 PM
David Concevida's Avatar
Same issue got fuel and compression, but no spark. Spark plugs are new. Spark plug wires are good. I got 0 Volts off both of these wires on the cap.
BLK/YEL 0 Volts
YEL/GRN 0 Volts
TexasCheddar
29
10-11-2013 04:44 AM
toyolla86
Honda Civic (2001 - 2005)
09-19-2010 06:39 PM
streetsweaper
13
10-03-2005 05:36 PM
Ace of Spades
02-28-2005 06:52 AM
hondamagic98
07-31-2003 03:53 PM
Quick Reply: 00 Civic - No Spark, No Start.
