Civic 2005 D17A1 turbo
Old 07-11-2009, 08:21 AM
Gian"vtec"'s Avatar
Default Civic 2005 D17A1 turbo
Hi, I'm from Panama City, Panama, I have a Civic 2005 D17A1 non vtec, I installed a T3/T4 Turbo, i have it already at 7psi, but I want to know what is the maximum boost that the engine cant takes without open the head or changes on the stock materials.
Been considerated that this is my daily drive car.
I have a Profec B II boost controller so I can stage 2 settings of boost, LB -HB
The only that I changed are the injectors of 440cc, a B16A2 Intake Manifold, Clutch Stage 3, and a SAFC II to control the AirFlow
Old 07-11-2009, 09:17 AM
Curiouz_G's Avatar
Default Re: Civic 2005 D17A1 turbo
what trim turbo is the T3/T4 hybrid?
How much duty cycle are your injectors running at?
What A/F ratio are you at currently?
The biggest limiting factor might not be the turbo, but your injectors. Not to mention if youre on a stock cam, you WONT be making TOO much more power above 7-10lbs.
Old 07-11-2009, 09:42 AM
Gian"vtec"'s Avatar
Thats what i want to know...ok 7 to 10lbs.
Thanks a lot bro.
Old 07-11-2009, 09:50 PM
01em2slvr's Avatar
i decided to post here instead of a new thread. im just curious cuz i want to turbo my civic but still have it as a dd. how much boost can i run stock with out changing internals. looking to spend under a 1000$. i just want to add some pull to my em2. 01 ex.
Old 07-11-2009, 10:35 PM
Ben850's Avatar
6-7
Old 07-12-2009, 09:29 AM
Sanji
toyomatt84's Avatar
This thread is for you: https://honda-tech.com/zerothread?id=1897200
cmiller219
08-16-2007 08:09 PM
slows2k
12-25-2005 05:19 PM
wade
09-15-2004 03:20 PM
underpressure02
04-22-2004 11:52 AM
BoostedsiR
03-05-2004 05:42 AM
Quick Reply: Civic 2005 D17A1 turbo
